Group Buy on NEW-STYLE MAF's for Twin Turbos/GT2s
Old Aug 12, 2005 | 02:05 PM
sharkster's Avatar
Heya guys, I spoke to the supplier and if you guys want I can get them pretty cheap for $249 each for this group buy. These are the NEW style MAFs as used in the Boxsters from 05 and up... I've used this one and found it to be more durable than the older ones. Even if you don't have a modified car these things tend to go so let me know either via Email to alex@sharkwerks.com or PM or just repond....
No limits on these as yet!
Old Aug 12, 2005 | 02:09 PM
collin996tt's Avatar
Senior Member
collin996tt is infamous around these parts
The MAF is only part of the problem. Can u throw a set of FR6 plugs in there also?
Old Aug 12, 2005 | 02:10 PM
sharkster's Avatar
LOL for 01s? They are SUUUUPER cheap... sure if people want them
Old Aug 12, 2005 | 02:11 PM
sharkster's Avatar
$5 per plug
Old Aug 12, 2005 | 02:15 PM
StephenTi's Avatar
StephenTi is infamous around these parts
How have these been tested and proven? Visually, how do they differ in design/construction? Is it plug/play? I'm definitely interested...
Old Aug 12, 2005 | 02:24 PM
sharkster's Avatar
Hi Stephen I'm doing a swap and yes it is plug and play. I've been using one since Jan of this year. A lot of the 04 05TT's come with this MAF.
Old Aug 12, 2005 | 02:30 PM
KJM3SMG's Avatar
KJM3SMG has a reputation beyond reputeKJM3SMG has a reputation beyond reputeKJM3SMG has a reputation beyond reputeKJM3SMG has a reputation beyond reputeKJM3SMG has a reputation beyond reputeKJM3SMG has a reputation beyond reputeKJM3SMG has a reputation beyond reputeKJM3SMG has a reputation beyond reputeKJM3SMG has a reputation beyond reputeKJM3SMG has a reputation beyond reputeKJM3SMG has a reputation beyond repute
is this similar to that thing with Imagine Auto Boxster MAFs?
Old Aug 12, 2005 | 05:00 PM
ebaker's Avatar
ebaker is infamous around these parts
Has the new MAF been tried/datalogged on a stock unflashed 996TT?
Old Aug 12, 2005 | 05:04 PM
Ruiner's Avatar
Now THAT is the key. Can we get a confirmation on this? (I do believe you, but I want to make sure before I throw in on this...).
Old Aug 12, 2005 | 05:05 PM
sharkster's Avatar
Works fine on stock cars.. After talking to Stephen and Todd though for anyone below a Stage IV aka 700, 750 they feel we should stick to the original ones. I know the dealer has a software update for the new-style one...
Old Aug 12, 2005 | 05:22 PM
ebaker's Avatar
I found a TSB on re-flashing early Boxters when the late Boxter MAF is installed. Is a dealer reflash of a stock 996tt available or necessary?
Old Aug 12, 2005 | 05:43 PM
Ruiner's Avatar
Great question. I, too, would like to know the results.
Old Aug 12, 2005 | 06:34 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Works fine on stock cars.. After talking to Stephen and Todd though for anyone above a Stage IV aka 700, 750 they feel we should stick to the original ones. I know the dealer has a software update for the new-style one...
Are you saying that lower HP cars, which are less likely to damage the MAF, should upgrade to the 986 MAF, but higher HP cars that are more likely to damage the MAF should NOT change to the 986 MAF??? Is this suggestion the result of problems arising when the 986 MAFs are used in higher HP cars???
What does the software update do??? Does the update write over the existing ECU program?
Thanks Alex,
Craig
Old Aug 12, 2005 | 06:50 PM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
IM INTERESTED TOO..
Old Aug 12, 2005 | 08:54 PM
PorschePhd's Avatar
It is actually the lower end kits and stock that are not crossing over well. The upper kits have been ok..so far.
