DIY for pulling MAF ?
Old Aug 14, 2005 | 07:16 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Question DIY for pulling MAF ?
I've never pulled my MAF......what's the 1,2,3 or has someone posted a pic before?.........TIA.
Old Aug 14, 2005 | 07:41 PM
Zippy's Avatar
1. Unplug it - push the flat sides of the plug together. It should make a little clicking noise. Then pull plug off of maf.
2. You will need a special little wrench to get the 2 screws out. The EVO intake comes with this tool. I don't know where to get it otherwise.
3. Pull out the MAF. Using a little trist back and forth while pulling works good.
4. Applying a little gob to the "O" ring of the new MAF before tristing it back/forth into the air tube is helpful, although I'm not sure gob is the correct lube to use
5. Put in the 2 screws (don't over tighten) and connect the wire back up.
Mike
Old Aug 14, 2005 | 07:51 PM
GreggT's Avatar
Thanks...........OE air box removal required 1st?.....the 2 screws or torx?
Old Aug 14, 2005 | 09:07 PM
Zippy's Avatar
You can leave the airbox in. torx is the ticket.
Old Aug 14, 2005 | 10:11 PM
vipertestarossa's Avatar
vipertestarossa is a jewel in the roughvipertestarossa is a jewel in the roughvipertestarossa is a jewel in the rough
security torx
Old Aug 15, 2005 | 02:13 PM
GreggT's Avatar
OK.....so it is not behind the air box, apparently is easily accessable.......and the 2 screws that hold it in are not a standard torx size ?
Old Aug 15, 2005 | 02:23 PM
wross996TT's Avatar
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
BLKMGK
May 31, 2016 04:32 AM
Kjeldaas
Feb 15, 2016 11:46 AM
Alex Wu
Sep 23, 2015 09:05 AM
NRoy7
Sep 19, 2015 06:59 AM
