Need ECU fault code help
Old Sep 23, 2013 | 05:11 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
Looking for some insight into why I keep getting a pair of p1145 and p1155 codes-and corresponding CEL, re-occurs every few hours on my '03 GT2, have attached freeze frame data via a generic OBD2 I use(yes I know I need a better diagnostic tool lol). Occurs only under light load/throttle. Always has a MAP reading of 255kpa????
Car has an EVOMS stage 3 package on it currently, last GIAC update done in 2007, runs between 1.1-1.3bar(127mph trap) runs stock fuel pressure and I believe stock injectors(yikes!)...I think the tune/lack of fuel system upgrade is responsible....
I have given the car in the last ~2000miles/few months:
-both new primary Bosch o2 sensors
-new Bosch plugs and Beru coils
-New Bosch MAF
-New Mahle fuel filter
Appreciate any insight, this one has me confused
Thanks!
Old Sep 23, 2013 | 06:15 PM
I would do a pressure test to 20 psi...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 23, 2013 | 08:01 PM
993GT's Avatar
thanks for the suggestion, I imagine testing whole system from MAF pipe would be advised?
Has anyone seen a MAP sensor failure? Seems odd the freeze frame data is always saying the same '255kpa'....might purchase one as they're really cheap anyway
Old Sep 26, 2013 | 04:43 PM
993GT's Avatar
Markski, thanks for the advice, made up a pressure tester today and found a major leak coming out of the passenger-side wastegate rod seal, should have known better to pressure test the system...guess it's time to look at wastegate upgrades..
Old Sep 26, 2013 | 05:19 PM
you live and learn.... good find...
9.66
click to view
BLKMGK
May 31, 2016 04:32 AM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
Lucid Moment
Sep 12, 2015 01:12 PM
Yogi911
Sep 9, 2015 08:20 PM
Nuke
Sep 8, 2015 09:09 AM
