Hitachi MAF vs OE MAF output?
Old Oct 3, 2013 | 06:35 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
Does anybody know how the Hitachi MAF sometimes substituted in our car output differs from the Bosch? For example, for any given situation is the MAF outputting .5v less than the Bosch would or does it vary?
If it is a constant decrease throughout the range then I am thinking about a plug and play circuit that would allow me to use the MAF without tuning.
Anybody have the part number for the Hitachi MAF?
Old Oct 3, 2013 | 07:44 AM
sinKing's Avatar
Quick research shows the Hitachi outputs a max of 5v and is at .5v with no air passing. I would assume the Bosch also has a voltage, probably .5v but that is just a guess, with no air passing over. From what I understand, and this could be wrong, both have the same maximum output voltage but the Hitachi sees more flow to get to max. If all of these statements are true then my original circuit idea won't work as I had hoped. The ECU calibration would be far easier than the circuit necessary.
Old Oct 3, 2013 | 09:46 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
would replacing the MAF pipe with a larger diameter unit and re-calibrating the tune allow us to see greater flow rates using the same MAF sensor? Assuming no turbulence is created when upsizing the pipe diameter, the accuracy level of the MAF should remain near the same, no?
Old Oct 3, 2013 | 09:52 AM
sinKing's Avatar
From my research on MAF's I think you're right. I would be interested to hear what a tuner says.
Old Oct 3, 2013 | 02:18 PM
our MAF pipe is already a pretty large diameter. i have not seen something this big used from a factory before.
#TeamAIM
Old Oct 3, 2013 | 05:56 PM
993GT's Avatar
for sure, but there's always bigger, could always just step up a section of the MAF pipe to ~5" too, as long as turbulence isn't created... think it's worth a shot for a tuner to try out
Old Oct 4, 2013 | 03:53 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Part number is HTC AFH75-01A
Audi number 06 C 133 471 A
If u still wanted it ?
Old Oct 4, 2013 | 05:33 AM
johnspeed's Avatar
for sure up but there's always bigger, could always just step up a section of the MAF pipe to ~5" too, as long as turbulence isn't created... think it's worth a shot for a tuner to try out
I believe keeping velocity up in that area is just as important if not more so than making a bigger volume pipe.
Then after that section would the rest of the intake plumbing benefit from it?
Old Oct 4, 2013 | 08:37 AM
993GT's Avatar
Would probably be a compromise solution, perhaps lacking some sensitivity at idle/very light throttle/flow but gaining the ability to read/not max at very-high power levels...think it's worth looking into for the guys that are having MAF issues and should be pretty easy for anyone with some light-fab skills and a datalogger/tuner to work with
Cheers,
Old Oct 4, 2013 | 12:16 PM
Andrew@GIAC's Avatar
Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !
Yes, that is how we typically do it. The Hitachi MAF does offer better drivability, and the larger housing allows for full resolution.
Old Oct 4, 2013 | 12:26 PM
johnspeed's Avatar
But as you said, with the Hitachi one.. Most like because that one can handle/read a bigger volume, lower velocity?
Old Oct 4, 2013 | 01:59 PM
Yes, from what I've seen the Hitachi has better resolution than the OEM Bosch.
Old Oct 4, 2013 | 02:23 PM
sinKing's Avatar
I think the Bosch uses an integrated IAT sensor. Does the Hitachi as well?
BLKMGK
May 31, 2016 04:32 AM
WheelsupZR1
Oct 20, 2015 08:36 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
panas001
Sep 27, 2015 02:51 PM
bongnation
Sep 25, 2015 02:58 PM
