What Tune?
Old Oct 28, 2013 | 10:25 AM
mbgt72's Avatar
mbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud ofmbgt72 has much to be proud of
Originally Posted by TeCKis300
Confirmed that she has a 5 bar this weekend.
Question - How much hp does the stock fuel system with a 5 bar support?
While it's probably not able to support the full use of the turbo's, I am octane limited for hp anyways with the **** grade 91 in CA.
Best way to see whats on the table is to do a log with a durametric cable and look at the injector duty cycle. It'll tell you when the fuel is running our and the ecu starts pulling things back. It's hard to say at X power b/c of different turbos delivering the power in different means and the other factors of the car / weather / fuel type / etc.
Old Oct 28, 2013 | 08:55 PM
TeCKis300's Avatar
TeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of lightTeCKis300 is a glorious beacon of light
mbgt72, thanks and I get that it's probably the best way given all the variables.
Is there a commonly accepted figure that stock injectors will support on the standard 3.8 bar fpr vs 5 bar?
Coming from the supra world, a quick and dirty convention was that per cc of injector flow, roughly equaled to supportable hp. So something like a 600cc injector, equated to 600 crank hp worth of airflow.
Something I need to figure out still, and possibly with the durametric once I get it is an inconsistent response from the tune/motor. Sometimes it doesn't seem to do the full 1 bar of boost. And other times, there will be lazy response.
I've already fixed a couple of boost leaks at the divertors and a minor one at the TB rear seal. I need to pressure test again to see if there's any other issues. I suspect a MAF and/or check valve issue yet to be resolved.
XLR82XS
Oct 5, 2015 07:02 AM
Tiago
Sep 14, 2015 10:06 AM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
