Stock Gearbox Power Levels?
Old Nov 14, 2013 | 10:56 AM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
I was wondering what power levels the stock gearbox will handle?
Also how much would it cost to strengthen it.
Talking around 750whp.
Also are there other weak links that show face around this level?
Old Nov 14, 2013 | 11:31 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
As long as you can stay away from the dreaded misshift, the tranny will hold well over 1000hp. It's the torque that will kill it mostly. 3rd gear seems to break first. Mine is still bone stock. Knock on wood.
Old Nov 14, 2013 | 12:36 PM
cjv's Avatar
cjv
Moderator
I do not know where the upper limit is. Wider square cut gears are available, but are noisy. Friction coating helps. You can install steel syncro's and last but not least a tranny cooler. Here are some pics of the cooler/pump on ours.
Tranny oil pump.
Oil Cool
Tranny tapped and lines being installed.
Old Nov 15, 2013 | 09:21 PM
pwdrhound's Avatar
+1 on what CVJ said. A tranny cooler goes a long way towards prolonging the life on these cars especially if you track them or have an LSD which will add heat due to the friction of the clutch packs. I have a set up very similar to what CVJ runs. With over 30 track days on it, it's a proven set up. Details of the cooler are below.
https://www.6speedonline.com/forums/...il-review.html
Old Nov 15, 2013 | 09:56 PM
cjv's Avatar
cjv
Moderator
You took yours a step farther with the auto thermostat. We manually activate.
Old Nov 15, 2013 | 10:04 PM
Turkish's Avatar
Turkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond repute
oh boy here we go again...
Old Nov 15, 2013 | 10:25 PM
pwdrhound's Avatar
My set up is totally hands off but I do have an override ON switch that I normally activate at the track prior to going out to get the oil circulating as opposed to waiting till it hits 200F. Other than that it's basically exactly the same set up.
Old Nov 16, 2013 | 07:48 AM
CJV is right, I am deleting my comment……..it isn't worth the time…..
Old Nov 16, 2013 | 08:10 AM
cjv's Avatar
cjv
Moderator
Wealth Manager, I have not been on the 996tt/GT2 forum much lately so I have not had a chance to view how some people interact. The fact the comment seemed to be ignored seems to indicate members take him with a grain of salt.
I would hope in the future Turkish understands how his comments are viewed and how it effects others. I would not lower yourself to back handed insults. It only tends to spiral downward. This is what the reporting of a post is for. Believe me, there are plenty of mods who will check it out and take action is warrented.
I truly hope this puts an end to this type of behavior and tension among perticipants.
Last edited by cjv; Nov 16, 2013 at 08:39 AM. Reason: Removed copied quote in the interest of cooperation
Old Nov 16, 2013 | 08:35 AM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
Repeating someone else's eternal wisdom ...
Plenty of info on "Stock Gearbox Power Levels" in the search function............
Old Nov 16, 2013 | 03:13 PM
32krazy!'s Avatar
i didnt get to see the o/t posts but i truly hope it doesnt deter you from posting on here cjv. i appreciate all the pictures, advice and knowledge you and others have posted here. im working on a build as we speak and have already saved myself from making some expensive or uneeded mods just from listening and watching. thanx again to all those willing to openly share their knowledge with me.
007 Vantage
May 27, 2014 11:49 PM
pwdrhound
Oct 1, 2012 03:10 AM
Sep 17, 2011 01:54 PM
Brucem
Apr 20, 2006 07:31 AM
