Coolant Leak?
Old Nov 28, 2013 | 07:04 PM
Pelvic Tornado's Avatar
Pelvic Tornado is infamous around these parts
Coolant Leak?
I came outside and my car had a little pile of what I believe was coolant on the ground. It looks like it was coming from this rubber part under the car.
Does anyone know what this is or maybe how much something like this will cost to repair?
I checked the coolant level in the expansion reservoir and it was sitting on the Min line so I'm assuming it either a slow leak or it just started happening.
Any advice is greatly appreciated!
ID:	306461   Click image for larger version
Old Nov 28, 2013 | 08:59 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
I've had a similar small leak like that when it got really cold last year. Apparently the aluminum piping and the clamp/strap on the rubber have different expansions rates in the cold which allows a small amount of coolant out.
Old Nov 28, 2013 | 11:02 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Originally Posted by timccloud
add some coolant stop leak
Never ever do that good way to mess up your engine and water pump. If the leak continues just fix it the right way. It's in a good place atleast shouldn't be too hard.
Old Nov 28, 2013 | 11:59 PM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Angry
says who ?
Old Nov 29, 2013 | 12:05 AM
996tt550hp's Avatar
says who ?
This is not a honda this is a 30k porsche motor. It will clog your system up ask anyone here and see if they did it........ or see who responds on putting stop leak in there coolant.
Old Nov 29, 2013 | 12:09 AM
timccloud's Avatar
worked well on my supercharged boxster
It actually ran cooler after adding
Old Nov 29, 2013 | 12:12 AM
996tt550hp's Avatar
It will work and at the shop i guy had a very nice boxster that did the samething 2 years ago well after 10k he now has a new engine from the samething over time it clogged the water pump and over heated the head. So it can happen it's just when.
All because he had a water pump leak a small leak.
Old Nov 29, 2013 | 07:00 AM
jpflip's Avatar
Pelvic Tornado : You will found some information here: https://www.6speedonline.com/forums/...d-housing.html
Look at the fourth post. The part#15 should also be ordered with 16 and 18…Easy job but lots of coolant will come out….
Glasgo
Nov 30, 2015 02:37 PM
freddiemac
Oct 7, 2015 11:05 AM
flewis763
Oct 4, 2015 04:14 PM
