700whp - 800whp What kits did you OPTION and SELECT
whats the safest whp obtainable on 91 without meth?
Look at my build thread up, the dyno sheet from BBI was at 1.8bars
I was talking with a local tuning shop a few days ago and telling them my plans for a build and they warned me against meth due to not being able to control the correct amount that is making its way into the cylinders and that its been know to cause issues with only 2 cylinders cooling and the rest of the motor still continuing to run hot. was warned that I would not be able to completely tell unless I was running the Proefi
Any thoughts on this?
. I am not talking from word of mouth, but actual experience.
you can run meth but dont tune it as if its on race gas... and it will be fine...
many that tune for meth run 15 degrees of timing in mid range or higher and lots of boost.. a no no in my opinion... use the meth as a cooling agent not a octane booster and your motor will stay together...
2001 996TT 3.6L and stock ECU
I would never go to that tune shop ever again cause they don't know **** about running meth. I have been running it now for over two years, I use the alky system cause it's been proven for years. My boy Turbo Mike has been running meth and 91 for around 10years now without a single issue. He is currently running it on his 997 GT2 on stock motor making over 800 whp on stock motor with 1.6bars. He's got 32k miles on the car and knowing him that setup went in at 2k miles
. I am not talking from word of mouth, but actual experience.btw real Meth comes in the blue VP M1 cans and doesn't need gasoline to make power =P
