HELP! New Fuel Pump broke twice within a year!
Old Dec 27, 2013 | 09:04 PM
porsche996tt_tpe's Avatar
porsche996tt_tpe is infamous around these parts
Car is 2002 996 TT. I replaced the fuel pump with a brand new one in 2013/2 and it broke again on 2013/6 and had it replaced with a brand new pump. Now 6 months later it just broke again, now in the garage...
I did a little search and didn't come up with much. Has anyone had repeated fuel pump failure in their TT? Could the incoming power from the relay frying up the pump motors?
I'm working with the mechanic to make sure that we don't have the same problem re-occurring...
Thanks a lot for your help!
D.
Old Dec 27, 2013 | 09:24 PM
rmc1148's Avatar
I would check for obstruction in fuel line causing excessive back pressure. Could cause over heating/burning out of pump I will assume fuel filter is clean. Could be spike in voltage but I doubt it.
Old Dec 27, 2013 | 10:18 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Fuel pump going out once is pretty rare but it happens. Fuel pump going out twice smells fishy to me....
Old Dec 28, 2013 | 09:00 AM
Tim941NYC's Avatar
Are you sure it is the pump? And not first the pump went and and now the hose split? Or in the other order. I have seen quite a few dead factory pumps. Hard starting is a sure sign.
Old Dec 28, 2013 | 03:55 PM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
pump
I am on my third fuel pump. First one the u-shaped rubber hose split. Second one, died after four years. Third one now having warm start problems, which tuner says is a bad check valve, so I will salvage a check valve off dead pump.
Note that if you have a cheap hose or valve go, Porsche does not sell individual components, so many replace the whole pump when really a $3 part is shot.
Lesson here, is keep all of your old parts for salvage.
Old Dec 28, 2013 | 05:41 PM
'02996ttx50's Avatar
i'm going with "hose split" too. it usually isn't the pump but the line. lousy deal.
Old Dec 28, 2013 | 07:09 PM
Yeah, I'm very sure is the pump (the motor) not the hose or the valve. When replaced, the entire pump is always replaced, not just certain parts.
Gas filter has been replaced as well.
The car just all of a suddenly lost its power. There hasn't been an intermittent failures or signs.
Everything seems normal when it's replaced... just can't believe two brand new pumps just went out like that....
Old Dec 29, 2013 | 05:15 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
maybe your fuel returnline isnt free, check it from the fuelpressure regualtor to the fuel hat (dont forget the fuelcooler to check)
Old Dec 29, 2013 | 11:35 AM
evil 996tt's Avatar
evil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud of
Anyone have a used fuel basket they want to sell?
Old Dec 30, 2013 | 06:44 AM
Hi, Winnigt2, Can you explain a bit more? I don't fully understand. I'd like to relate this to my mechanic in the way I can understand. Thanks!
Old Dec 30, 2013 | 08:18 AM
winnigt2's Avatar
if the return line behind the fuel pressure regulators has not enough retournflow it is possible the fuelpump has to work hard and fuel goes hot
check the the returnline from the fpr out or fuel cooler to the fuelpump basket ...you only need air to check it (blow carefully out and check if it have free retourn....easy to do and no cost of money)
check the fuelpump filter mesh at the pump if it has a free flow..
hope that helps a little
Old Dec 30, 2013 | 08:30 AM
Thanks.
I do hear a momentary break (very brief) in the engine roar, especially when I accelerate...
Old Dec 30, 2013 | 08:48 AM
winnigt2's Avatar
best way is to check your fuel pressure at the fuelfilter, there is a valve to check the fuelpressure ...at standstill 3,8 bar and under boost 3,8bar plus boost 0,8 bar = 4,6bar..... and at idle under 3,8 bar...
other failures are possilble
Old Dec 30, 2013 | 09:24 PM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Thumbs up
Subscribed! Tks for sharing!
Old Jan 1, 2014 | 05:26 PM
Thanks! I'll ask to have it checked out. What other failures may still be possible? I figure the chance of having two bad parts in a row is really slim...
