Just bought a new clutch, Sachs 2.5...
Old Jan 1, 2014 | 08:09 AM
TXTurbo996's Avatar
TXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud of
Can anyone give me an estimate how much install will be? I've read the dealership will take the engine out, independents will just remove the tranny and cut the time in half. About how much am I looking at here?
And no, I don't feel like doing it myself in the garage. I don't have a lift, and my days of doing clutch installs on my back while cursing tight spaces are over.
I've also got a local shop that has done some body work on my car, they deal primarily in BMW's and can literally rebuild those from scratch, set them up as all out race cars, etc... but they want to take a stab at it and would give me a good deal. I'm not sure a clutch install is the type of job that I want to give them to get their feet wet LOL. Thoughts?
Finally... the GT2 clutch conversion. My current clutch is not leaking, it's perfectly fine... But does the tranny have to come out to do the conversion? I was thinking I would upgrade if the stocker goes bad, but if I had to pay to remove the tranny again with a lightly used clutch in it, I'd be pissed.
Thanks guys,
Todd
Old Jan 1, 2014 | 08:42 AM
32krazy!'s Avatar
figure 8 hrs for the clutch swap and another 1hr for the gt2 conversion IF your doing the oem setup. the p/s conversion and master cylinder labor is the same for either a bracket gt2 swap or oem
Old Jan 1, 2014 | 08:54 AM
TXTurbo996's Avatar
Thanks for the reply. I was thinking about ordering the kit from EVOMS. If I did OEM, wouldn't that require drilling the transmission casing? Is it cheaper to buy oem parts rather than the bracket types?
Old Jan 1, 2014 | 09:50 AM
32krazy!'s Avatar
oem does req. drilling thats what the extra hr is for. super simple to do. evoms kit has all oem parts and a braided line plus the dot 4 fluid and some plugs for the p/s pump. i did the oem setup and spent less than 550$ for all the parts needed to do this. i couldnt justify another 400+ for a bracket fluid and a few plugs
the trans case has beefed up bosses inside the casing which line up perfectly with the holes drilled for the studs. all thats needed is a step drill bit and a dremel to clearance the inside of the case for the gt2 clutch fork. took less than an hr to do everything(drilling and clearancing)
Old Jan 1, 2014 | 10:17 AM
johnspeed's Avatar
I have the same clutch and I like it a lot compared to my 2 previous CM set-ups. . Modulates great, close to stock..
I run stock flywheel, DM, and have NO GT2 conversion.
most private shops around here in Chicago area charge between $800 to $1100 for swap..
Good Luck..
Old Jan 1, 2014 | 02:13 PM
TXTurbo996's Avatar
I'm planning on running the stock flywheel too. I've had other cars with the lightweight flywheel and the chatter gets annoying in a street car IMO.
32Krazy, thanks for the info! I think I'll just order the OEM parts as that sounds like a significant savings, and just do a regular GT2 install.
Old Jan 1, 2014 | 04:49 PM
be aware of your oem flywheel.. if its warped your clutch will not disengage properly...
and your back to square 1
dont convert to gt2 stuff unless you ahve a shop that did it... mind you.. if used breake fluid vs. penstosin.. they screw that up and your in for $1100 in parts alone....
$900 for indi is fair and lots of bleeding required...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 1, 2014 | 09:58 PM
TXTurbo996's Avatar
I'm in Dallas, we have an RAC performance here, I'd hope they would have done this before, I'll have to ask.
If I need to order another flywheel I will, and I'd go with a LW one since the stockers are much more expensive. Will cross that bridge when I get there. My car appears to have been babied by the previous owners though, so I think it will probably be fine.
Old Jan 1, 2014 | 10:13 PM
johnspeed's Avatar
I have original flywheel and I am on 3rd clutch in 45,000 miles.
GSP
Sep 9, 2015 05:31 AM
sparks
Sep 8, 2015 03:03 PM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
