DIY - CV Boot replacement
Old Jan 3, 2014 | 12:07 AM
Slider's Avatar
With the help of some members at 6SP, I was able to replace my outer boots without a trip to the dealer. I have detailed the experience here in the hopes that the next guy knows when he is in for before he starts...
ID:	317015   Click image for larger version
ID:	317016   Click image for larger version
ID:	317017   Click image for larger version
ID:	317018   Click image for larger version
ID:	317020   Click image for larger version
ID:	317021   Click image for larger version
ID:	317022   Click image for larger version
ID:	317023   Click image for larger version
ID:	317025   Click image for larger version
ID:	317026   Click image for larger version
ID:	317027   Click image for larger version
ID:	317028   Click image for larger version
ID:	317030   Click image for larger version
ID:	317031   Click image for larger version
Old Jan 3, 2014 | 12:26 AM
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
Very nice writeup. Thank you.
Andreas
Old Jan 3, 2014 | 08:18 AM
jpflip's Avatar
Very good job Slider! Thanks for sharing!
Old Jan 3, 2014 | 08:45 AM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
I just did this the drivers side last weekend and sure could have used this write up then! The only problem I had was the clamps. How did you get them off and back on without destroying them? I got them off but couldn't get them on. I changed the wheel bearing while I had it apart also. I ordered that fancy Schwaben air boot expander and busted two boots trying to get over the abs ring So I took my inside joint apart and slid the front one on. I would be doing the right side tomorrow but ECS screwed up my shipping and I'm very frustrated with them.
Old Jan 3, 2014 | 01:21 PM
benw's Avatar
benw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant future
awesome post!
Old Jan 3, 2014 | 01:30 PM
32krazy!'s Avatar
rep to you!!
Old Jan 3, 2014 | 09:39 PM
Slider's Avatar
Originally Posted by Vantaredoc
... The only problem I had was the clamps. How did you get them off and back on without destroying them? ...
The clamps are a friction fit to start - You just wrap them around the boot, squeeze and they hook and lock onto the overlap. Then, you use a special tool to crimp the last millimetre or so tighter. (Look t the clamp picture above...)
To take them off, poke a screwdriver into the crimped area to pry it apart. Once uncrimped, the overlap should just unhook. If it doesn't, you can help it a bit with a screwdriver. When you reuse them, just crimp again. It should be good for a couple of uses before another crimp will break it.
Old Jan 4, 2014 | 09:58 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Nice
Old Jan 5, 2014 | 01:01 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Great write up Slider, very well done
Old Jan 6, 2014 | 09:07 AM
Vantaredoc's Avatar
Thank you for the response. I tried with every tool in my arsenal and I could not get it to hook back on the new boot. I even straightened the krimp! There has to be some kind of tool that compresses it so you can hook it. I had to just use zip ties to get it back together to get it out of shop and back home. My order of new boots for passenger side just showed up today so I will do the passenger side this weekend. I purchased a ratcheting type clamp tool and new clamps to install on all of them!
I would like to add, while replacing the cv shafts or boots I read it is also a good time to replace wheel bearings. I replaced the drivers side bearing by purchasing a 12 ton press from Harbor Freight. Instead of fabricating weird shaped pieces to hold carrier in press due to its shape, I simply turned carrier upside down, pressed out old hub and bearing and then placed new bearing (which I had in freezer for a day) on the press first and then set carrier on top of new bearing then used old bearing on the opposite side. I made a piece to cover old bearing and just pressed the carrier down onto new bearing. It worked like a charm! I could probably take pictures of the right side when I do it this weekend.
Old Jan 6, 2014 | 11:19 AM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
Great job and the pictures are fantastic! Thanks for sharing.
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old Jan 6, 2014 | 01:21 PM
Slider's Avatar
It would be great if you could post pictures - I'm not completely following how you replaced the bearings...
Old Jan 6, 2014 | 01:38 PM
Vantaredoc's Avatar
I will, but don't expect no fancy write up...lol It was quite easy and I was hesitant after reading several DIY's showing different pieces people made to hold the carrier due to its odd shape. Took longer to assemble the cheap press than to press out old bearing and press in new one! On the back side of the carrier there is a lip that the bearing seats on from the front side. I started the new bearing in the carrier by lightly tapping it and then set the carrier on the press with new bearing down. I placed the old bearing on the lip from the back side and centered my press on some pieces of steel over the old bearing and pressed the carrier down onto the new bearing.
Old Jan 13, 2014 | 06:37 AM
Vantaredoc's Avatar
As promised
Click on the first picture as it is a video! If the fronts are this bad, Now I am wondering about the rear bearings! I guess 80K miles is high mileage for these cars!!
ID:	320748   Click image for larger version
ID:	320749   Click image for larger version
ID:	320750   Click image for larger version
ID:	320751   Click image for larger version
ID:	320753   Click image for larger version
ID:	320754   Click image for larger version
ID:	320755   Click image for larger version
Old Jan 13, 2014 | 08:05 AM
Slider's Avatar
Wow, that press is pretty big. Where did you get the new bearing?
