Dyno Day Today!!!!(Stage 2 IA)
Old Nov 6, 2003 | 09:31 PM
AMG ETR's Avatar
Originally posted by 20C4S
Evan,
the fan idea is not that unreal... when u are actually driving the car, the wind, or the air just like a big fan (even stronger wind) that sucked in to the engine... am i right??
Yes, but the thing is, that during normal driving the car will heat up...it will not have water being sprayed into the intercoolers and on the engine to cool it down (and a fan directly on it...). It is not totally unrealistic....if you have a C02 system like Chad
Evan
Old Nov 6, 2003 | 10:41 PM
cjv's Avatar
cjv
Moderator
Evan,
Your experiment with water spraying showed how temperatures pay a big part in produced hp and torque.
Actual is a run conducted at actual temperature, barometric pressure and actual humidity.
Standard Corrected is actual corrected to a barometric pressure of 29.92 in/hg and a temperature of 68 degrees F.
SAE converts actual to a barometric pressure of 29.23 in/hg and a temperature of 77 degrees F.
From your water experiment Actual can be a bonus or penality depending on actual temperature and pressure. Standard Corrected will naturally make tests look far better (in most cases) with it's corrected low temp. and SAE J1349 Rev90 is a practical situation that can be compared anywhere in the world.
The Standard Corrected is popular with tuners and aftermarket manufacturers because it makes their numbers look bigger.
Old Nov 7, 2003 | 08:03 AM
AMG ETR's Avatar
I don't know anything about that Chad, you aren't speaking my langauge anymore
The temp of the test was around 85 thats all I know though...
Yes the water and a couple extra fans made a HUGE difference...
I am a bit worried about running that much HP out of these little K16's though...I think I am gunna turn it down a bit...
Evan
Old Nov 7, 2003 | 10:42 AM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
Evan
How do you turn it down?
Old Nov 7, 2003 | 11:15 AM
HotRodGuy's Avatar
Originally posted by sharkster
BTW you'll get a buncha peeps saying 13% is way too low... I've heard some people say 25%, others 18% an well just about anything Who cares, seems fast enough and you're plenty rich. Get a set of new/bigger turbos and lean things out lol
on automatics maybe, i've never heard anything more the 18% on manuals. The consensus is about 15 from what i've seen and used.
Old Nov 7, 2003 | 12:30 PM
AMG ETR's Avatar
Turn down the wastegates a bit...
Evan
Old Nov 7, 2003 | 01:22 PM
sharkster's Avatar
Careful to make sure you are setting them dead on accurate. The range on those things is so small between "insane" and "normal". Make sure you have a realy accurate gauge...
Old Nov 7, 2003 | 01:30 PM
AMG ETR's Avatar
I don't have a guage, I will have my shop do it next time I am there...trust me they know what they are doing
Evan
Old Nov 7, 2003 | 02:40 PM
msindi's Avatar
Evan, was this an AWD dyno or RWD??
Sorry if you answered this but I did not have time to read through whole post...
Where was this done anyway??
Old Nov 7, 2003 | 02:42 PM
AMG ETR's Avatar
This was a RWD dyno (look at pics ).
You have PM
Evan
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
jyupitt1
Sep 23, 2015 06:26 AM
