245/35-19 PSS on 19 X 9" Wheel - Offset?
Old Jan 24, 2014 | 02:56 PM
DNugget991GT3's Avatar
^wow. that wheel color is awesome.
your wheel is an 11, mine is a 12. that explains (and shows) why the tire sidewall appears smaller.
Old Jan 24, 2014 | 02:59 PM
mlife2878's Avatar
mlife2878 has a brilliant futuremlife2878 has a brilliant futuremlife2878 has a brilliant futuremlife2878 has a brilliant futuremlife2878 has a brilliant futuremlife2878 has a brilliant futuremlife2878 has a brilliant futuremlife2878 has a brilliant futuremlife2878 has a brilliant futuremlife2878 has a brilliant futuremlife2878 has a brilliant future
For sure. I think both profiles look good.
Steve K - btw, love how your wheels look! really sharp. Are the outer lips custom painted a different color? Sorry for the off topic question. Feel free to PM me, just curious
Old Jan 24, 2014 | 03:41 PM
mLife, thanks i love the color your wheels, my other wheels are painted that same color, but a few shades lighter.
the wheels are painted two tone just like OEM gt2 wheels.
the "lip" is painted silver, and the spokes are painted satin black metallic.
btw, i am finally manning up and getting a real DD.. looking at e46 330Ci (ALWAYS wanted it when i was younger)... im bout that m-life too lol
ID:	324981   Click image for larger version
Old Jan 24, 2014 | 11:42 PM
pwdrhound's Avatar
Originally Posted by JayRacing
Not purchased yet, but 19x11 w/305/30-19. I was told a 12 wheel was too wide to stretch the 305s. However, per the simulation the 12" wide would fill the wheel wells more. They will be Michelin Pilot SuperSport.
You were misinformed. Stock OEM 997 GT3 tire is 305/30/19 on OEM 19x12 wheel...Perfect fit.
305/30/19 on 19x12....
Old Jan 25, 2014 | 09:29 AM
JayRacing's Avatar
JayRacing has a spectacular aura aboutJayRacing has a spectacular aura about
Excellent. Great info!
Old Jan 25, 2014 | 09:49 AM
evil 996tt's Avatar
evil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud of
PWDRHOUND - Are your wheels true RUFF wheels? The car looks great! Do you run spacers on the rear wheels?
Old Jan 25, 2014 | 02:18 PM
pwdrhound's Avatar
No. I sold my RUF wheels. While they were very nice, the RUF wheels are fairly heavy and the rears require the use of 35mm adapters on the wide body cars. Since I track my car and swap between 3 different sets of wheels, having to use adapters is impractical. The wheels in the picture are built by Champion. 19x9 and 19x12. Forged and very light, about 8 lbs lighter per wheel than my RUFs.
Old Jan 25, 2014 | 08:17 PM
mlife2878's Avatar
Haha. The e46 is a great platform and solid daily. I'd pick one up in a heartbeat so def recommend one! Good choice.
Old Jan 26, 2014 | 12:23 PM
evil 996tt's Avatar
Agreed, i'm not digging big spacers on the track. So Champions with RUFF centercaps? They look great!
Old Mar 23, 2014 | 08:51 PM
JayRacing's Avatar
Ok, following up on this thread. I received my Forgestar wheels on Wednesday, the Michelin Pilot Super Sport tires became available on Thursday at Tire Rack, Friday I received the tired (Thanks to Damon at Tire Rack), and then Saturday got the tires mounted and installed the wheels.
Front Specs:
Forgestar CF5V Silver Semi Concave 19 X 9 +50
Michelin Pilot Super Sport 245 35 19
Rear Specs:
Forgestar CF5V Silver Deep Concave 19 X 12 +45
Michelin Pilot Super Sport 305 30 19
There is very slight rubbing at the rear fender liner and the front are very close to the spring perch (stock 996TT suspension still):
Final Thoughts:
I need to get some 3/4 shots to post and I don't have any real ride height numbers, but there is a 2.5 finger wheel well gap in the front and a 2 finger gap at the back. I will probably be researching lowering methods here next. The fitment at the front is pretty good. I don't plan on changing anything there right away, I'll just see if there are any signs of rubbing over time. Does any one see any major issues with the 3-4mm clearance with the spring perches? I could even shave down the perches slightly without adversely affecting their strength to gain some more room.
In the rear, it seems like 5-7mm spacers would take care of the fender liner rubbing. However, the fitment is already pretty square with the fenders. I have read about the 996 GT2 fender liner brackets. Would these solve my issues? I even had a friend suggest using a heat gun and some pressure to reform the plastic in the affected areas since it's very minor. As always, I appreciate everyone's input/insight.
ID:	350140   Click image for larger version
ID:	350141   Click image for larger version
ID:	350142   Click image for larger version
ID:	350143   Click image for larger version
ID:	350145   Click image for larger version
Old Mar 23, 2014 | 09:40 PM
pwdrhound's Avatar
Front Specs:
Rear Specs:
Final Thoughts:
You are fine with 3-4mm clearance on the front perches. GT2 fender liner brackets in the rear help as they create room at the base of the liner by the IC hose by eliminating the TT bracket attachment there. ET40 in the rear is ideal if you have rolled fenders. If you haven't driven you car hard yet with your new set up then you will find that you will rub the fender liners more when you do. The reason is the fact that with all the rubber in the suspension you will get quite a bit of movement of the rear end under hard braking which will cause the rear wheels to pull back and in contacting the fender liners. I used to have the same issues before going to full monoballs. Statically I had about 1/4" worth of clearance between the tire and fender liner yet after a track outing I would have a hole rubbed through the liner. The rear end moves around quite a bit with all the stock rubber bushings..
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
Well that sucks... i've got the exact same tire setup going on this week in the same size wheels and tires but mine are a +47 rear so mine will be 2mm closer to the inner fender so i guess mine will rub like crazy.
Old Mar 24, 2014 | 07:23 PM
JayRacing's Avatar
Thanks, yes the ET40 in the rear would have probably abated this clearance issue with the fender liner. In conclusion, I borrowed a heat gun, heated the area affected with the wheel/tire still in place, but the vehicle raised on jack stands. Then I stuffed a rolled up terry cloth detailing towel to apply pressure to remold the plastic, finally I quenched the area with a spray bottle of water and pretty easily gained the 5-10mm clearance I need.
Old Mar 24, 2014 | 10:50 PM
daedalus's Avatar
Thanks for the info Jay! I have a heat gun so I guess that will be my course of action as well.
Old Mar 29, 2014 | 09:51 AM
JayRacing's Avatar
What are typical tire pressures for you guys on the street? Again:
Front Specs:
Forgestar CF5V Silver Semi Concave 19X9 ET50
Michelin Pilot Super Sport 245/35-19
Rear Specs:
Forgestar CF5V Silver Deep Concave 19X12 ET45
Michelin Pilot Super Sport 305/30-19
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
PelicanParts.com
993 Turbo Vendor Classifieds
