Water Methanol for 996 TT - Nitrous Express
Old Mar 29, 2014 | 09:46 AM
lesliegems's Avatar
lesliegems is infamous around these parts
I bought the following with an N20 system that I was going to use on a turbo BMW M3. It is a top of the range Nitrous Express Water Methanol Kit.
Could this be used on my Porsche Turbo S 996 instead of Aquamist etc ?
http://www.nitrousexpress.com/15027-water-methanol-gas-efi-stage-3-digital-progressive-controlled.html
I would use this for turbo cooling and added power maybe in line with a race gas tune and/or E85
The NX GAS Stage 3 is unmatched for accuracy and adjustability in water-methanol injection systems. This system can be used on any forced induction engine, or ANY engine with a traditonal EFI system, and features our LCD display with on-the-fly adjustability. Extremely easy to set up and dial in - the software creates a delivery map based on boost or EFI signal from just a few easy to set points you punch in from the drivers seat. The LCD Screen displays boost pressure, fuel injector duty cycle, as well as water-methanol injection percent. Quick, easy, positive adjustments are made with 2 push buttons. Low profile design allows for easy-to-view and discrete mounting.\n\nKit includes: UHO (Ultra High Output) Pump 3 Quart Reservoir LCD Screen, Pushbutton Digital Variable Mapping Controller 2 Nozzles To Cover a Wide Range of Horsepower 10 feet High Pressure Tubing (1200psi burst) Comprehensive Instructions
Notes
http://www.nitrousexpress.com/oldwebdocs/instructions/wm_stage3_instructions.pdf
Part # Description Price
15027 Water Methanol, Gas EFI Stage 3, Digital Progressive Controlled
Any and all thoughts welcome as usual
Old Mar 29, 2014 | 04:46 PM
group.america's Avatar
group.america is infamous around these parts
Good kit, used it on a turbo BMW with small shot of nitrous... used the water/methanol as a cooling agent AND octane booster
THE NX kit is every bit as good as the Aquamist IMHO
Old Mar 29, 2014 | 05:44 PM
32krazy!'s Avatar
no way a progressive based unit will ever be as safe as a pulse bandwidth unit. its not even in the same league.
Old Mar 29, 2014 | 06:07 PM
I stand humbly corrected, thx
Old Mar 29, 2014 | 09:32 PM
Urban's Avatar
Urban has a spectacular aura aboutUrban has a spectacular aura about
I have the aquamist HFS-3 going on my BMW shortly, it has the pulse width modulation valve injection system which I consider to be one of the best out there.
nlakind
Nov 6, 2015 10:15 AM
Oct 6, 2015 05:20 AM
orbelo
Aug 30, 2015 12:26 PM
Aug 19, 2015 06:55 PM
