missfire
Old Apr 12, 2014 | 08:21 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
missfire
How do you know/tell if you have a missfire in the upper rpm range?
Old Apr 12, 2014 | 08:34 PM
rmc1148's Avatar
Have codes read.
Old Apr 13, 2014 | 03:02 AM
fairbird's Avatar
fairbird has a spectacular aura aboutfairbird has a spectacular aura about
CEL will flash , you can hear misfires .
Old Apr 13, 2014 | 11:34 AM
log It. Simple
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 13, 2014 | 12:08 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
You'll hear and feel it for sure. I had it happen to me under strong boost, and a fresh set of plugs fixed it.
Old Apr 15, 2014 | 01:34 PM
Because_R4CEC4R's Avatar
Because_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud of
I had some misfires due to bad coils and plugs, I certainly felt it the car was cutting power repeatedly then the check engine light started flashing. Wasn't a good feeling, but it's not a hard fix if this is what is happening to you too.
Old Apr 15, 2014 | 04:54 PM
group.america's Avatar
group.america is infamous around these parts
I just did my Durametric test and have the same problem..... my car boosts 1.25 bar and has intermittent misfires in 2 cyl, also rich at various times yada yada yada
New sparkies, larger injectors =
hopefully
Old Apr 15, 2014 | 06:26 PM
hopefully
Injector? You sure it's not a coil? You'd be less likely to run richif it was an injector failure. That should cause you to run lean.
Old Apr 15, 2014 | 06:27 PM
Tim941NYC's Avatar
Rich and misfire do not go hand and hand.
Old Apr 16, 2014 | 12:37 PM
Yes and/or coils, Protomotive did some charts of my fueling and we think more likely that
Sorry, on the Durametric there is a measure of cylinder misfire and cylinder rough running, on 1 test I had one cylinder showing a misfire, another run it was a different misfire and then on the rough running cylinder measure I got values from -3.3 to as high as 6 across each cylinder... trouble is I cannot find what the measure means and what is normal for a 996 TT S
Name:	Fuel Values.png
Old Apr 16, 2014 | 12:40 PM
This is some of the charts from my Durametric tests
Seem to think the car wants to pull in a LOT more fuel and the system says nope, I am maxxed out baby
Name:	Duty Cycle Gas.png
ID:	360601   Click image for larger version
ID:	360602   Click image for larger version
TabooPc
Apr 25, 2014 10:27 PM
Cj_boxster
Jan 27, 2014 10:55 AM
Zippy
Aug 21, 2012 06:00 PM
topspeedua
May 9, 2012 01:16 PM
996TT_STEVO
Jul 4, 2008 08:54 AM
