high octane gas
Old Sep 12, 2005 | 08:13 PM
maxjamie's Avatar
Porsche Rocks
maxjamie is infamous around these parts
high octane gas
I live in northwest Florida and for the past few weeks the only gas available is 87 octane unleaded after Katrina. Any down side of running this 87 gas for few gas tank fulls until 93 octane is available? Should I consider adding those octane boosters? TC
Old Sep 12, 2005 | 08:34 PM
orijinal_poser's Avatar
orijinal_poser is infamous around these parts
if 87 is the only option available, do not push your engine at all. cruise everywhere and slowly accelerate. basically, just make sure the engine doesn't ping or knock, especially since turbo cars should be run with higher octane....
the octane boosters might trigger some CEL codes and they can possibly damage the catalytic convertors, so it would probably be a good idea not to use it unless you are catless.
Old Sep 12, 2005 | 09:52 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
No boost for you.
Old Sep 12, 2005 | 10:16 PM
Ruiner's Avatar
Re: high octane gas
Octane Boosters (sold in stores) are a scam.
"Raise your octane 2-3 points!"
Yeah, it raises you from 87.0 to 87.2!! If you REALLY want to raise your octane rating, get some Toluene or Xylene. Toluene is 114 octane and Xylene is 117 octane (if I remember correctly).
Do the math:
2 gallons of 114 Toluene + 8 gallons of 87 octane = 92.4
http://www.elektro.com/~audi/audi/toluene.html
Toluene
R+M/2...114
Cost...$2.50/gal
Mixtures with 92 Octane Premium
10%...94.2 Octane
20%...96.4 Octane
30%...98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Old Sep 13, 2005 | 10:03 AM
KJM3's Avatar
KJM3 is infamous around these parts
Re: Re: high octane gas
Just don't get the Xylene or Toluene on your cars paint as they will ruin the paint!
- KJ
Old Sep 13, 2005 | 10:17 AM
Ruiner's Avatar
Re: Re: Re: high octane gas
- KJ
Yes, YES it will.
Old Sep 13, 2005 | 02:06 PM
Fanman's Avatar
Fanman is infamous around these parts
They had an article on this in Sport Compact Car afew months ago. The NOS racing octane booster did push up the octan 3 points, but the stuff is about $7-$8 a bottle, not this crappy 99 cents stuff. They had a few others that only pushed it up about a point. Toulene & Xylene raised it up quite a bit, but anything over 30% can damage you engine.
Old Sep 13, 2005 | 03:21 PM
Ruiner's Avatar
The problem is that some of the $7-10 stuff contains methylcyclopentadienyl manganese tricarbonyl (MMT). Not good at all and typically not street legal. I wouldn't recommend using it if you have o2 sensors on your car.
Old Sep 13, 2005 | 06:41 PM
DT04R's Avatar
DT04R is infamous around these parts
Any experience with Torco? Several of the guys running superchargers on C5/Z06's swear by the stuff:
http://www.torcoracefuels.com/catalo...products_id=28
Though it's marketed for upping the octane of 93 -> ~104, I would suspect it would increase lower octane gas as well.
I was thinking it would be a great way to haul some extra octane to DE events (vs. $7/gal race gas).
DT
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
turbotuner20v
Sep 11, 2015 12:02 PM
The Oss
Aug 24, 2015 08:19 PM
