Code P0197.....
Old Apr 28, 2014 | 07:21 PM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
Code P0197.....
Porsche fault code 125-oil temp
This is the fault that keeps coming up with Durametric. I have searched and could not find much. I don't have any issues and no problems checking oil. I installed a new temp sensor with no change. Advise would be appreciated. Thank you!
Old Apr 28, 2014 | 07:36 PM
AdamNoone's Avatar
AdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant futureAdamNoone has a brilliant future
PM me your email. I have a pdf that may help you.
Old Apr 28, 2014 | 07:47 PM
Vantaredoc's Avatar
You have mail! And thank you!
Old Apr 29, 2014 | 11:55 AM
wross996TT's Avatar
0-37 P0197 125 Oil temperature sensor - below limit
Possible fault cause
♦ Temperature sensor faulty
♦ Wiring harness
♦ DME control module faulty
Old Apr 30, 2014 | 06:53 AM
Vantaredoc's Avatar
Well everything to the DME checks out! Strange thing is I have no problems checking the oil level Looks to me like if the temp sensor circuit was having issues, I wouldn't be able to get up to temp to check oil level.
Now I'm wondering if I should replace DME or leave it alone. If I did replace DME, would I loose function of my Durametric cable and my software flash?
BTW...This code was always in the DME from when I first got the car in November.
Old Apr 30, 2014 | 09:25 AM
32krazy!'s Avatar
If it truly is in the dme no need to replace it. You can have yours rebuilt much cheaper. I'm guessing that's not the issue .
Old Apr 30, 2014 | 09:40 AM
rmc1148's Avatar
Probably not the issue but I would clean connector at sensor.
Old Apr 30, 2014 | 10:40 AM
Vantaredoc's Avatar
I have proper resistance with my ohm meter at the DME from the sensor. If you think it's not the DME, I would be willing to try what you suggest. By following the flow chart from the PDF AdamNoone sent me everything is correct. If I disconnect the sensor, I'm not able to check the oil. If I clear the code while engine is at operating temp, the code does not come back until engine cools off and I restart. Code registers and stays, and then when engine warms up, I can check oil level and clear code....EVERY TIME
Old Apr 30, 2014 | 04:42 PM
32krazy!'s Avatar
donnie i don't have an answer for you but if you want i can connect you with my shop. they had layinbacks dme rebuilt and they also have another place that rebuilds dme's.
from my experience i was told my injector driver was likely toast and needed a new dmd. bought a used unit had all the immobilizer codes and such swapped over. 800$ later i had the exact same problem as before. dme wasn't the issue.
the shop can have yours inspected and then you could decide if you want rebuilt new or used. i think dgreen has a used dme for around 800$
do you think the coolant sensor could be the culprit? if the engine rads oil level when warm but not cold maybe the coolant sensor is interacting with the oil sensor in some way
Old Apr 30, 2014 | 04:46 PM
Vantaredoc's Avatar
Thank you. I'm wondering if I should just leave it alone as it is not causing any issues. It only shows up when I read it with Durametric. I keep going back to "if it ain't broke don't fix it"...lol
Old May 10, 2014 | 09:13 AM
Vantaredoc's Avatar
Well it gets better! Today out of the blue I start car, put it in gear and idle climbs to 1150 and accelerator has no response! Code is P1266. I cannot find good info for P1266. Since I have had the car I have had the accelerator not respond on few occasions, shut ignition off, restart and work perfectly. I forgot the code but it was tps code. Any clue what the P1266 might be? Thanks in advance.
Old May 10, 2014 | 09:50 AM
AdamNoone's Avatar
I just emailed you another PDF flow chart. Doesn't look good. Looks like the DME is you issue..
Good luck
Old May 10, 2014 | 10:11 AM
Vantaredoc's Avatar
Thank you. That makes sense as to the other faults that just pop up I think it has been bad for a long time as the Car Fax shows the instrument cluster has been changed a couple times when it was new and and service history shows electrical issues for service visit. How hard is it to program new DME (or do you have to) and can I change it myself? Do I have to get a DME specifically for a Tip? I sure hope this is the last of the "surprises" for this car because I really like it, but I do not tolerate vehicles that keep giving problems
Funny thing is, I had never seen that code till today. I connected the Durametric cable and had my laptop connected and was opening the Durametric software while I decided to move car to shade inside building. I started her up and BAM!
Old May 10, 2014 | 08:10 PM
I doubt its the ecu... ecus go bad from grounding out issues... and someone playing with wires touching them etc...
disconnect the battery... try again... do a quick pressure test just to make sure no vacuum leaks etc... the oil temp sensor is usually from a loose wire on the oil sending unit...
the ecu just doesn't go bad on its own... its usually human error
good luck
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 10, 2014 | 08:59 PM
Vantaredoc's Avatar
good luck
markski
You should know me by now! I leave no stone unturned! This is not new with this car! I wish someone could recognize this car and give me some history. It's personal now and I will find the issue. I will keep this one as a parts runner and get a .2 for my garage at home..
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
PelicanParts.com
997 Vendor Classifieds
Oct 5, 2015 01:07 PM
nagual911
Oct 1, 2015 01:52 AM
