Any 997TT Plenum, TB, manifold into 996TT DIY??
Subscribe
May 7, 2014 | 08:57 PM
I am just trying to see how the lines are ran on the 996tt to the 997TT Plenum?
Do they have to be rerouted?
Are you not using certain connections?
I looked at the difference between a 996 and a 997 turbo IPD plenum and there seems to be various difference between the connections.
Any help is appreciated.
Reply
May 7, 2014 | 09:07 PM
Or can you use a 996tt Plenum in the 74mm size which would match a 997tt throttle body. but does it match the 997 intake manifolds?
Reply
May 8, 2014 | 06:08 AM
Quote: Or can you use a 996tt Plenum in the 74mm size which would match a 997tt throttle body. but does it match the 997 intake manifolds?
Nope
Reply
May 8, 2014 | 06:30 AM
Quote: Nope
Yea I wound up figuring that one out last night. Now I just have to see how the lines are ran.
I think you have to get creative with how you run them.
Reply
May 8, 2014 | 07:25 AM
Found a 997 plenum with the 996 setup on top. Bolt in
Reply
May 8, 2014 | 09:03 AM
why not just use the 996tt one?
/i dont know the differences
Reply
May 8, 2014 | 09:08 AM
The 996 plenum does not fit with the 997 manifolds. Nor does the stock plenum fit with the 997 TB.
Reply
May 8, 2014 | 04:22 PM
Shouldn't the shop doing your build know how to do this?
Reply
Subscribe
