View Poll Results: What tire size?
Pirelli PZero Rosso 305-25-19
66.67%
Michelin PS2 275-30-19
22.22%
I don't give a flyin' fu@k, it's not my car!
11.11%
Voters: 18. You may not vote on this poll
Help: Need Tires on 19 x 11 AVUS wheels
Guys:
I am getting the wheels mounted today and need a suggestion on what size tire to wrap on the wheel.
Wheel is a 19 x 11 Avus AF-503 on a Rear of a C2 narrowbody.
Should I go with a 275-30-19 Michelin PS2 or a 305-25-19 Pirelli PZero Rosso?
You can't put a 275 on a rim that wide. The rim range on that tire is only up to 10" . Stretching a full inch more will overheat it and it will fail. Don't do it.
Go 295/30 19, or 305/30 19
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
i know, i know. you da' man arling. i just wanted to make sure.
i just called ben at wheel's boutique in miami and had him order the pzero rosso's like this:
305 - 25 - 19 Rears
235 - 35 - 19 Front
with this damn hurricane making way, doubt i will have them on for tuesday.
son of a......
305 - 25 - 19 Rears
235 - 35 - 19 Front
son of a......
Wow........so you actually bought new wheels without a specific plan of for what rubber you were going to run?
Most people with the 11J 19 have been running 315s (on C4s and Turbos) assuming 30-35 offset but this is for a narrow Body C2?......should be aahhh.....'interesting'.
from that, the pzero's erupted.
you don't agree on the pzero sizes for the wheels I bought?
The only luck I have ever had with 19's on a C2 that looked proportionate and still fit was the S-03 Pole Position in 245/35 and 285/30. That was on 8.5/10" BBS LM. Bridgestone RE750 and Conti Sport Contact 2 I know won't work and look right. The rim range is still correct on the 285, but I've never tried an 11" rim on a C2. I bet you're going to have to roll the fenders at minimum as well.
Good luck.
Good luck.
damon@tirerack.com
Or use this link:
damon@tirerack.com
Or use this link:
Good luck.
Good luck.
they do play the offset around. i've exchanged mails with DiMisa & suggusted the best way for him. i had to know very detailed spec to come up the solution.
Good luck.
Good luck.
all these opinions are starting to scare me.
arling, just open a shop in south florida, my life would be so much easier.
