Maf?
Old Jun 1, 2014 | 05:07 PM
Montescew's Avatar
Montescew is infamous around these parts
Maf?
Hi Guys,
My '01 TT has been throwing a P0300 code, but I now have a 0028 too.
Can someone please chime in and let me know if cleaning it has had positive results for you? I was thinking of giving this a shot first opposed to replacing. I have used CRC before with good results on other things. Thanks.
Old Jun 1, 2014 | 05:52 PM
rmc1148's Avatar
They make special spray for cleaning MAF but I would replace with new. I have cleaned them and they improve but they usually act up again fairly quickly.
Old Jun 1, 2014 | 06:48 PM
Montescew's Avatar
That's what I was told by someone else, it sounds like a short-term solution. Thanks for the confirmation, I will just replace it. I just hope it takes care of these codes.
Old Jun 1, 2014 | 06:55 PM
Tim941NYC's Avatar
When was the last time you did plugs and coils? Is the car tuned?
Old Jun 1, 2014 | 07:01 PM
Tim941NYC's Avatar
0028 is bank 2 high lift I think. check your retaining bracket on the solenoid between cylinder 4 and 5 coils.
Old Jun 1, 2014 | 07:13 PM
Montescew's Avatar
My car has close to 18k on it, the plugs and coils are original. Not tuned. Do you not think the MAF is the culprit? I might hold off for right now or try cleaning it so see if this clears the codes temporarily. Thanks Tim.
Old Jun 2, 2014 | 03:27 PM
Tim941NYC's Avatar
I do not believe your maf is the culprit. Even if your car has 18k miles it is still 13 years old.. parts do fail. I just take out coils on a 05 turbo S with 27k, all 6 where cracked!
Old Jun 2, 2014 | 05:38 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
it's been years but had maf prob , cleaned it and all was fine for 500 og 600 miles then it went bad again . put a new one in a few years ago and all is fine it's an 01 also.
Old Jun 2, 2014 | 06:45 PM
'02996ttx50's Avatar
cleaning mafs is a stopgap fools game on these cars. get a new one. i am still doing penance for suggesting in here ad nauseum ( when i was young and foolish ) that the cheap knockoffs were ok to use. they suck.
bosch OEM Part Number: 996-606-124-00-M14
Old Jun 2, 2014 | 07:32 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Make sure you discount the battery when you clean or replace the maf. This will allow the computer to adapt.
Old Jun 2, 2014 | 10:04 PM
Montescew's Avatar
Thanks Pat, I will make sure to do this.
BLKMGK
May 31, 2016 04:32 AM
drug delivery
Oct 24, 2015 11:04 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
panas001
Sep 27, 2015 02:51 PM
Stormdog
Sep 26, 2015 03:18 PM
