**Need help** understanding PPI result
Old Jun 28, 2014 | 12:07 AM
911man's Avatar
911man is infamous around these parts
PPI just came back with the following results on a 2002 turbo with 96,000 Kilometres - should I be worried?
- FOUND MISSFIRE CODES FOR CYL #3+6.
- 1955 OPERATING HOURS. 41,942 IGNITION CYCLES
AT REDLINE (UNDER THROTTLE), 137 IGNITION
CYCLES OVER-REVS (MISSED SHIFTS)
Thanks for your help!
Old Jun 28, 2014 | 05:36 PM
BOOSTD's Avatar
BOOSTD is a splendid one to beholdBOOSTD is a splendid one to beholdBOOSTD is a splendid one to beholdBOOSTD is a splendid one to beholdBOOSTD is a splendid one to beholdBOOSTD is a splendid one to beholdBOOSTD is a splendid one to behold
It needs plugs.
Old Jun 28, 2014 | 08:47 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
It sounds like a bad driver owns it and it needs coil packs.
Old Jun 28, 2014 | 08:49 PM
2swoosh's Avatar
2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future
depends on the price bro those are not bad
Old Jun 28, 2014 | 09:51 PM
911man's Avatar
Thanks for responding, the Porshe performance shop who did the PPI mentioned that this car was driven extremely hard and that these numbers are some of the highest numbers they have ever seen on a PPI. I am just worried that this car was abused and have more wear and tear on the engine than whats normal.
What would be an appropriate amount of ignition cycles at redline and over-revs if these numbers are considered bad? Car is priced at $38K
Old Jun 28, 2014 | 09:53 PM
911man's Avatar
Thanks for your reply. What makes you say the previous driver was bad and what would coil packs have done?
Old Jun 29, 2014 | 06:50 AM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
If the car is tuned it changes the redline and will show a ton of over revs - do you know if it is?
Old Jun 29, 2014 | 10:03 PM
911man's Avatar
What is considered tuned? Just so I know what to look out for - Thanks
Old Jun 29, 2014 | 10:45 PM
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
Originally Posted by 911man
Thanks for your reply. What makes you say the previous driver was bad...?
'Cause judging from the number ignitions at redline, sounds like dude used the limiter to remind him when to shift.
Look for more than .6 or .7bar of boost, that's usually a dead giveaway. Also, the DME has a value for "Number of programming operations." If this value is greater than 1 (the factory tune), then that's another strong hint - unless a dealership reflashed with a factory tune, which I'm guessing doesn't happen all that often.
For reference and whatever it's worth, I bought my car with 29,693 range 1 ignitions, and 323 range 2. The Porsche tech (very experienced guy) said no big deal, previous owner didn't "baby" the car, but by no means did he abuse it either - as evidenced by every other item he inspected.
So my advice would be to look at the complete picture instead of just one aspect.
-V
Old Jun 30, 2014 | 02:09 PM
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
I'm pretty sure there is a difference between type-1 and type-2 overrevs. I think type 1 is bouncing off the limiter, and type 2 is surpassing the limiter.
While I don't think its good to bounce off the limiter every shift, 130 times touching the limiter doesn't sound bad to me... Type 2 overrevs is the one that needs to be looked for IMO.
Old Jun 30, 2014 | 02:59 PM
p556guy's Avatar
p556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud ofp556guy has much to be proud of
Type 2 would be downshifting into 2nd when you meant to catch 4th.
Type 1 is hitting the rev limited before you shift.
Old Jun 30, 2014 | 03:36 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
On a tuned car, that is incorrect.
There are many threads on this, you can log Type 2's with a tune where the rev limiter has been raised, and I'm not referring to a downshift scenario, which is certainly is ONE way.
Old Jun 30, 2014 | 06:23 PM
'02996ttx50's Avatar
^ +1
... only to add, not all tunes raise the rev limit as suggested upthread.
Old Jul 1, 2014 | 08:37 AM
Drew959's Avatar
Drew959 is a jewel in the roughDrew959 is a jewel in the roughDrew959 is a jewel in the rough
Is it 180 cycles per second? If so, this engine has run at the rev limiter for 233 seconds?
johnkent1212
NorCal
Sep 18, 2015 07:44 PM
Motams
Sep 15, 2015 08:59 AM
MrMiggy
Sep 14, 2015 02:18 PM
