alpha30/76 to HTA35/86
Hello,
what are the Pro and Cons upgrading from A30/76 to GT35/86hta .63?this is a 996 GT2 3.8l built by Proto.
I appreciate all comments.
Ali
Ali
gain HPs and lose some Spool
#TeamAIM
#TeamAIM
I know that HP gain will be huge,at least 200whp gain on 2.2bar but will I loose a lot of spool even with .63?
just do it you will never look back....
2001 996TT 3.6L and stock ECU
A30s are maxed out already ? Did you upgrade your fuel system ?
I think A3076+3.8 engine can do like 900-950 whp on high reading dyno (dynojet), but 86hta for sure can do 1250-1300 whp at 2.2+ bar
I had A3076 and now i'm running a slightly bigger turbo.. spool is like 400 rpms later and i can feel the difference in spool, but also in power delivery... i have no idea how a gt35 car would feel, but i suppose the difference will be even higher... my advice is to squeeze those alpha30s first and then move on to another level
On another note, how is your car performing till now ? Are you satisfied with the 3.8 upgrade ? Do you have any performance figures like 100-200 ?
sounds about right.
#TeamAIM
#TeamAIM
i suppose 500 rpms too, not less.. if you dont have your fuel system ready it makes sense to do everything at once and add turbos too and i think 3.8 goes well with the hta86... you will love the external wastegates for sure
1liter bikes arent anymore a problem for us for some time time, i used to pass them with FBO & stock engine+A3076 @1.5bar only.. I remember Mark did it too on stock engine and alphas... with your setup i assume there is no chance for the bikers..
