Loud humming noise from the crank case
Old Jul 24, 2014 | 07:26 AM
porsche996tt_tpe's Avatar
porsche996tt_tpe is infamous around these parts
Posting this as a request for a shop owner who's been working on this problem for months w/o solution...
Car is 996 turbo. The engine has a loud humming noise (like that of a bad bearing) from the crank case, from the center crank shaft. The sound was isolated using a stethoscope.
All the copper sleeves on the shaft have been replaced, along with other replaceable/wearable parts.
He finally swapped the whole crank case from another TT engine, the noise is gone. But he can't figure out why...
The shop-owner said, he's seen a few TT with the similar noise as they age, but most car owners simply ignore it.
Any inputs? thanks.
Old Jul 24, 2014 | 09:03 AM
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
Did the mechanic inspect the bearings?
Old Jul 24, 2014 | 09:12 AM
yes.
'02996ttx50's Avatar
^ the pinion/thrust bearing(s) will one day wear out. they dry out after enough heat cycles.
Old Jul 24, 2014 | 06:25 PM
Slider's Avatar
I just replaced my thrust bearing. It was only making noise under load. Foot off the gas - noise stops. It's a dead giveaway that the bearing is at fault. If your hum is full time and not limited to acceleration, it's not the thrust bearing.
Old Aug 12, 2014 | 05:58 AM
The ball bearings have been replaced with new. So it's not from the bearing itself.
The noise is apparent from idle to about 3000RPM.
The noise is gone when the major components in the crank case (incl. the shaft) are swapped with another spare.
Any inputs? Thanks.
Old Aug 12, 2014 | 06:17 AM
rmc1148's Avatar
It has to be either a bad new part or worn crank.
Old Aug 12, 2014 | 07:09 AM
A worn crank shaft means it's basically off-balance then?
Old Aug 12, 2014 | 07:16 AM
rmc1148's Avatar
Usually a worn crank will be noisy and or lower than normal oil pressure. If possible I would work a deal out with shop to exchange for lower crank assembly that is in car with new bearings etc.
BenTT
Jul 22, 2021 02:38 PM
pwdrhound
Sep 13, 2016 10:44 AM
BLKMGK
May 31, 2016 04:32 AM
jyupitt1
Sep 10, 2015 08:31 PM
ECS Tuning - VW
Sep 8, 2015 12:54 PM
