The Turbo is sputtering
Old Jul 27, 2014 | 06:33 PM
TTurbRon's Avatar
TTurbRon is a jewel in the roughTTurbRon is a jewel in the roughTTurbRon is a jewel in the roughTTurbRon is a jewel in the rough
So I took the turbo to the track this wknd and on my last 2 sessions out the car would sputter through hard corners as if it was starving from fuel. Runs fine in the straights but not through turns. Initially thought it was not enough fuel in the tank as I was only down to about a half a tank. Filled it up full and same problem next session out. No issues the first 2-25 min sessions out and drove home fine. Could the pump be failing? If it was I would think it would do it all the time not just through cornering. Fuel filter was done approx 3 yrs ago but only about 15k on it since. Afrs were good as I checked full throttle on the way home so I think inj are ok. Anyone experience this in there 996? Mine is an 01' with 47k on it. Thanks for the help in advance! Hope it's a simple fix.
Thanks,
Ron
Old Jul 27, 2014 | 08:28 PM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
I've nearly run my tank dry on a technical track, so that probably isn't the problem. Does it sputter on both hard left and right turns? Nothing during hard acceleration or braking? This is an interesting problem.
Old Jul 27, 2014 | 08:30 PM
TTurbRon's Avatar
Yes only on left & right turns.
Old Jul 27, 2014 | 08:38 PM
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
Could be faulty ABS sensors or something, do you get any flashing lights in the cluster?
Old Jul 28, 2014 | 05:44 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
Hmm that is weird. Sounds like wire is loose. Maybe injector. Or fuel pump
TTurbRon's Avatar
Unfortunately nothing. Wish I did it would tell me exactly what was going on. Thanks for the tips though.
Old Jul 28, 2014 | 05:46 AM
TTurbRon's Avatar
That's what I'm thinking.
Old Jul 28, 2014 | 08:43 AM
sodinishu's Avatar
sodinishu is infamous around these parts
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
Christian
Aug 24, 2015 12:56 PM
johnny.dangerous
Aug 21, 2015 10:48 AM
PelicanParts.com
Aug 20, 2015 02:57 PM
