Very Unhappy with my Clutchmasters fiber tough stage 3 clutch kit.
Old Sep 9, 2014 | 09:47 AM
  #31
Tim941NYC's Avatar
Originally Posted by NTIMD8
Yup its a sprung disk. Ive gotten used to the high engagement point and it holds the power for sure (although I only have about 500 HP). The main issue is the chatter on take off when it gets warm. Ive read a lot on the subject butt he odd thing is how some people have it with the CM3 setup and others dont. Im going to try the 2nd gear 4000 RPM method and hope for some reason it fixes the issue even though someone said it will only fix the on/off type engagement.
Did you use the CM pressure plate? I my experience the thinner a disc is the higher the pedal will be, I believe the kelvar disc is thinner then the stock.
Old Sep 9, 2014 | 10:12 AM
  #32
atisvt99's Avatar
atisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant future
I have a super "chattery" CM3 as well... I went with the LWFW too. I just got my car back from Protomotive and I think Todd's words were somewhere along the lines of "what in the world is this clutch? it's horrible..." haha...
I'll be taking this thing, and the AI flywheel out here before too long and going with the '11 GT3RS 4.0 clutch kit. That's what Proto uses for lots of clamping force and a stock feel.
Old Sep 9, 2014 | 10:30 AM
  #33
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
1600 damn. I dont mind chatter either. I need to bleed mine.
Old Sep 9, 2014 | 10:40 AM
  #34
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
Yup, Im using the pressure plate that came with the CM3 kit. I think I read it was a sachs pressure plate modified for more clamping power but I could be wrong.
Old Sep 9, 2014 | 11:02 AM
  #35
Tim941NYC's Avatar
There is a product that ram clutches sells that will help with the high engagement but will not work with pentosion. It is not a easy bolt in either. I feel your pain and clutches are so hit or miss. The same setup in two cars can be total different. I seen a lot of people where doing very well with the sachs 888 pressure plate and gt2 style solid disc, so I went that way with my daily and it is slipping. Pedal feels great tho. Who wants to go over kill on a triple and pay that freight. AND not know if you are going to like it!
EDIT: Don @ebs has a disc made for him that works very well up to 600 ft lbs, use the CM pressure plate.
Old Sep 9, 2014 | 11:39 AM
  #36
atisvt99's Avatar
I was told the same thing... Sachs PP, modified, etc... Maybe I can post a video of what it's like inside the car backing out of the garage and then going to take off in 1st. Haha... it's almost amusing (while I'm thinking about it, and NOT sitting in the car)
Old Sep 9, 2014 | 08:45 PM
  #37
NTIMD8's Avatar
Originally Posted by Vendetta
Try this and report back.
-V
OK so I did this. It was hard mentally to do it since it felt like I was abusing the car but I followed the instructions and so far the chatter is GONE!!!! I took the car out for a 30 minute drive a few hours after I did the procedure and it is soooo much smoother. No chatter on take off and no chatter on downshifts even if I don't rev match. I tried to replicate my drive to work in traffic by doing a lot of stop and go. Not sure if I got the clutch hot enough but didn't get any chatter at all. Next I tried a couple of hard launches as well as hard 1st to second shifts to make sure the clutch was not glazed and slip. I had no problems at all. The clutch held the power great and would chirp the tires on the 1-2 shift.
The real test will be when I am stuck in traffic for an hour on a hot day but so far this has worked!!!! *knock on wood*
THANK YOU!!!!!!!!!!
Old Sep 9, 2014 | 08:49 PM
  #38
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
Old Sep 9, 2014 | 09:05 PM
  #39
Tim941NYC's Avatar
^^^ "love it when a plan comes together..."
Old Sep 10, 2014 | 02:22 AM
  #40
32krazy!'s Avatar
any links to the product tim? i would love to drop my engagement about 1" and I'm gt2 converted so no petosin
Old Sep 10, 2014 | 08:14 AM
  #41
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
http://www.jegs.com/i/Ram+Clutches/798/78300/10002/-1?CAWELAID=1710630223&CAGPSPN=pla&catargetid=23000 6180000848344&cadevice=m&gclid=COzG9Jnq1sACFRNffgo ddD0Auw
I'm with you - running gt2 with an lines. In my case would be pretty simple to install. Think I'll give this a shot.
Old Sep 10, 2014 | 12:04 PM
  #42
Tim941NYC's Avatar
That is it. Any hydraulic hose shop should be able to put ends on the factory hose. If you want to use -4 out of the slave use this:
http://www.pegasusautoracing.com/pro...asp?RecID=9338
Get a crush washer to fit the 12mm side.
Old Sep 10, 2014 | 04:41 PM
  #43
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Yikes
I had a South Bend clutch in my car for about 2 days, until I had it replaced. It was horrible, ON/OFF engagement, very difficult to drive. Was recommended by a friend who owns a shop.
Not sure what version it was, however, it did NOT look like the pictures you provided. It quite possible they have gotten their **** together by now, who knows, personally you won't find many, if anyone running a South Bend clutch in their TT on this forum, so there could be some level of risk.
Good Luck.
Originally Posted by Ursoboostd
I'm having a South Bend daily Stage 2 put in now.
http://www.ecstuning.com/Porsche-200...Kit/ES2725216/
Old Sep 10, 2014 | 05:51 PM
  #44
NTIMD8's Avatar
As per my PM, I cant thank you enough for showing me that method. I hated the car for a summer and a half. It was so hard to drive. You had to give it 100% of your attention all the time. I was even thinking of trading it in on a GTR (which is a big deal for me as I have dreamt of a Porsche Turbo since I was a child). Drove it home from work in heavy traffic today and it was almost like driving it when it had a stock clutch. I even let my brother drive it just now who is over for supper. He swore he would never drive it again after stalling it 20 times the last time he drove it. His exact words were... Oh my god, I'm not afraid to drive your car anymore. It feels normal again. So awesome!!!!
Old Sep 10, 2014 | 06:58 PM
  #45
pwdrhound's Avatar
I have the 764PP/4.0disc/964RS LWFW along with GT2 factory hydraulics. Drives better than stock. Perfect modulation, zero chatter and virtually no noise. Proven clutch for 90% of people out there in my opinion without any surprises all for right at $2k in parts. No need to reinvent the wheel....
