diverter valve leak test?
Old Sep 23, 2014 | 08:29 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Originally Posted by The Pork Hunt
Not sure then, I was thinking a boost leak test from intake would pressurize both sides so you wouldn't see an internal leak of the 710N's. Shouldn't have same issue if you skip the intake and leak test from the turbos though. If this is the case and you hold steady pressure it sounds like they're fine to me.
That's why I'm puzzled...what if the diaphram in the DV are sticking but not torn? i would still hold boost right?
I just order 2 more 710n's
I'm just trying to figure out where the honking came from...or I just may be hearing things...
Old Sep 23, 2014 | 08:32 PM
geetee's Avatar
Originally Posted by '02996ttx50
understand. i only mentioned the evo's as i also once talked about my honking dv's when they were still bosch. still think you can rule them in/out by testing them specifically, but you have pro help here so i'll just wish you success. i wasn't going to live with that sound for more than a cpl days though geese dug it. gl w it.
I actually want your BOV..lol....after i switch out y pipe and can mount the BOV where it can easily reached though
Old Sep 23, 2014 | 08:46 PM
'02996ttx50's Avatar
i can't change much after the plenum since in cali they practically stick a camera up yer tailpipe for smog tests and the kommisars don't like aftermarket parts. i have even considered covering the evoms lettering on the dv's lol. i understand why you want as many stock ( looking ) parts as you can assuming that's why you won't dump the bosch? but i can say these dv's are not prone to failure, and for me that's just one less thing to think about. either way, they are a minor fix and yet we all fixate lol.
Old Sep 23, 2014 | 08:58 PM
The Pork Hunt's Avatar
The Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond repute
Can't say I've heard of 710n's sticking before but doesn't mean it can't happen. When you remove them just check the piston movement out for yourself for smoothness and see if the vaccuum port holds it back.
Old Sep 23, 2014 | 10:33 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
How do you know if your DV is functioning right?
I have upgraded 710N DV valves installed 10k miles ago. I'm boosting normal 1-1.1 bar and boost leak test holds 20psi with no leaks.
During back to back to back pulls...I swear I hear a "honking" sound coming from the rear once in a while..like a torn factory DV.
Those BOV's suck i found out mine were leaking for 4 months from Secondary Air Pump codes popping up all the time. Pressure test them from the top nipple if it doesn't hold psi then its leaking.
Old Sep 24, 2014 | 09:59 AM
Start with the pressure test. Make sure it's holding. It's easy to do and quick. It will eliminate everything including ripped F hoses and or clamps leaking.
Then worse case take the dvs out and test them manually.
Old Sep 24, 2014 | 01:56 PM
cburke996's Avatar
cburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of light
Newer 710N's are crap...they aren't even made by Bosch anymore. They sold the rights and design to a company called Kayser, and AFAIK all new ones say that on the side. I had some 710N's when they were still Bosch, and they lasted me about a year until one developed a vacuum leak (which threw secondary air codes, like 996TT550hp said). I bought a replacement 710N - a Kayser at this point. The thing honked like crazy from the get go. Held boost fine, but the honking was embarrassing. I returned that one for another 710N, thinking it was just a faulty one. Nope, the next one honked as well. I eventually just gave up on them and bought a set of Forge 007's, which have been great so far.
Old Sep 24, 2014 | 02:39 PM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
I have stock DVs and do low 7s on 60 to 130 with my 996 TTS, love that sound as they HONK and "explode"
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
Feelgood MD
Mar 24, 2016 09:35 AM
XLR82XS
Oct 5, 2015 07:02 AM
shifter_
Sep 8, 2015 12:07 PM
