DIY air filter change on 996 turbo?
Old Oct 19, 2014 | 11:38 AM
0396's Avatar
0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute
I'm sorry to ask what I thnk is a simple question. I've searched and can moly locate..is there a DYI , step by step on how to remove the air filter housing / filter? I think I'm loosing the ability to tinker / explore on my own.
Thanks in advance for your replies.
Old Oct 19, 2014 | 12:15 PM
32krazy!'s Avatar
remove the single bolt and the clamp holding the rubber sleeve.remove the mad plug rotate to the left approx 160* slide it upward and outward. when the box is off the car theres small bolts along the edge.
Old Oct 19, 2014 | 12:25 PM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
Simply download the repair manual.
Old Oct 19, 2014 | 02:25 PM
0396's Avatar
Thanks folks for the advice. .I'm missing the rotate the 160 degree to the left bit. Enjoy your day.
Old Oct 19, 2014 | 07:25 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
I can make DIY if you want.... -btw watch the rubber grommets on both ends (under the box) since they like to slip when you lift the box
Old Oct 19, 2014 | 07:33 PM
0396's Avatar
All, thanks for sharing your insight. I will have a go with it next week. Enjoy your week.
Old Oct 20, 2014 | 08:30 AM
Slider's Avatar
Do the first few steps in this DIY - Stop after Air Filter Rotation....
https://www.6speedonline.com/forums/...-pictures.html
Old Oct 20, 2014 | 10:25 AM
0396's Avatar
Thumbs up
Perfect ! Thank you. My brain must be in idle mode as I've totally over looked the MAF connections.
Thanks again all!
Old Oct 20, 2014 | 02:17 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
The first time was a little tricky, you have rotate more than 90 degrees to twist it out.
Old Oct 20, 2014 | 04:10 PM
MadWhip's Avatar
Its easy to get it out. But puting back is more tricky. Ones you master that, takes 30 sec.
SharkyShark20
Sep 19, 2015 09:54 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
