Forge Diverter Valve Install
Old Oct 24, 2014 | 11:16 AM
onenrg1's Avatar
onenrg1 is a splendid one to beholdonenrg1 is a splendid one to beholdonenrg1 is a splendid one to beholdonenrg1 is a splendid one to beholdonenrg1 is a splendid one to beholdonenrg1 is a splendid one to beholdonenrg1 is a splendid one to behold
So I ordered some forged motorsports diverter valves through TitanMotorsports and received them yesterday. I dropped my wife off at the airport early and decided to tackle this before work today. Actually, ended up going very smoothly. Even with me taking the pictures it took about 45 minutes. I think the key is having the right tools and I used common tools that you may already have in your toolbox. I have to say that I utilized the AWE Tuning instructions that were good until the clamps on the diverter valves.
Tools:
Needle Nose locking pliers (I liked these because it gave me a chance to manuever around while the clamp was loosened)
Slanted Needle nose pliers (Necessary for the diverter towards the front of the car)
10MM socket
Flathead Screwdriver
Step 1:
Remove the 2 10mm bolts holding the positive terminal to free up room to get at the diverter valves
Step 2:
Remove the left intercooler hose by utilizing a flathead screwdriver to pry up the clip
Step 3:
Remove the coolant cap and the coolant hose
Step 4:
Unclip the vaccuum hose by pressing on the grey clip and pulling apart
Step 5:
In front of the hose just removed will be a bigger hose connected to a plastic, white piece. Remove the grey C clip on the white plastic piece using a flat head screwdriver then pull back on the hose while using the screwdriver to keep the other end in position. Pull those hoses gently over to the right side of the engine bay.
Step 6:
Unclip the big hose on the F pipe (I used the locking pliers here) and separate
Step 7:
Remove the diverter valve closest to the rear by removing the top vaccuum line, and the 2 clamps
Step 8:
Removal of the diverter valve closest to the front of the car is hardest. The clip releases are facing the front of the car and here is where it gets tricky. Remove the bottom clip so you can pull the F pipe and diverter assembly out of the car. To do so I used the angled pliers with slight pressure on the diverter valve pulling it to the rear of the car gently. The goal here is not to remove the clamp at first but swing it to the rear of the car where you can get a better grip on the clamp. I included a picture of how I used the angled pliers to get the clamp towards the rear of the car
Step 9:
Replace with the new Forged diverter valves and follow backwards to install. Note the placement of the nipples on the new valves. The one closest to the front of the car will be in a 10 o'clock position and the one in the rear of the car will be in a 9 o'clock position. I zip tied the nipple vacuum hoses. Also, when placing the diverter valve in the front of the car you now have the opportunity to place the clamps in a better position to be reached. One final word of advice is to yank a little on the intercooler hose to make sure that clip is secure.
I have to say that I am very happy with the Forge Diverter Valves. I notice quicker response between shifts. Just overall better performance. I also am happy that they included stiffer springs for when I move towards turbo upgrades.
Some people stated having to drop the engine a little bit. I know that takes a little bit of time but I could have this job almost done in the time it would take me to place the car on jackstands and drop the engine. This job can easily be done using these steps. The key is having the right tools to get at the clamps.
Ping me if you have questions.
Hope this helps,
Last edited by onenrg1; Oct 24, 2014 at 12:33 PM. Reason: Pics didn't come through
Old Oct 24, 2014 | 09:31 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
Nice writeup! I've got them on my car as well though I didn't have to do the install but good info if they ever need maintenance or replacing.
Old Oct 26, 2014 | 02:17 PM
GeeTee2's Avatar
GeeTee2 is infamous around these parts
I did the job same as you did, it was not easy but I managed to do it !
I would recommand to check and secure the oil pressure transmitter electrical connections while doing this mod, you gain perfect access with both valves removed.
Old Oct 26, 2014 | 05:01 PM
onenrg1's Avatar
GeeTee2,
Were those connections that you mentioned loose? I didn't notice anything loose but wouldn't mind taking a second look if I may have missed something?
Old Oct 26, 2014 | 08:29 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
cool, thanks for write-up. I'm going to upgrade mines soon
Old Oct 27, 2014 | 12:54 AM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Great install write-up. May I suggest to also cover the Y pipe inlet while the hose is removed!
Old Oct 27, 2014 | 04:07 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Graet write up! Make sure to soap water test for boost leaks. My forged diverters need to be tighted every few months due to leaking.
Old Oct 27, 2014 | 04:36 AM
GeeTee2's Avatar
Originally Posted by onenrg1
GeeTee2,
When I removed my stock diverter valves, I checked the oil pressure transm. screws on the connections and they were not really tightened...
Old Dec 1, 2014 | 04:04 AM
Clyde Barrow's Avatar
Clyde Barrow is a name known to allClyde Barrow is a name known to allClyde Barrow is a name known to allClyde Barrow is a name known to allClyde Barrow is a name known to allClyde Barrow is a name known to all
Am I the only one to think they are in the wrong direction?
I mean, with Forges DV, the boost pressure is supposed to pusch the piston against the spring's strength!!!
Why would different springs with different strengthes be available?
Old Dec 1, 2014 | 02:53 PM
onenrg1's Avatar
When you run higher boost then you need a stiffer spring to avoid the valves from opening too soon. Most of us probably wouldn't need that spring change.
Old Dec 1, 2014 | 10:04 PM
I also have Forge DV and I put the yellow spring in each of them, with the hold (is that the good word?).
I speak about this:
So I placed the DV in the right direction.
I think that the risk with your instalation is that the spring close the piston too soon and before all the air is out. You lose the real advantage of the good product that is the DV Forge. ;-)
Old Dec 2, 2014 | 02:35 AM
desodangwe's Avatar
desodangwe is infamous around these parts
Old Dec 2, 2014 | 01:33 PM
onenrg1's Avatar
I run 1 bar. With a tune the green or yellow would be fine. You are probably right, I should have switched to the yellow since I know that once I change my intercoolers that I will run a bit more boost on race gas.
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Old Dec 2, 2014 | 05:34 PM
Yes the green spring is just enough for 1b. But there is no reason that your piston open itself too soon the way you put your DV.
Putting my DV the way forge does, and runing more than 1.2b, the guy from Forge proposed to me:
"I think that for the boost pressure you are running, you would need to run our yellow springs if you have access to them."
So that's what I did , with the hold.
The original green spring created a leak in my system.
Old Dec 3, 2014 | 10:23 AM
onenrg1's Avatar
I did run a boost leak test and found I have a slight leak but couldn't locate it. I was thinking of changing the Throttle Body O Ring as Markski suggested in one of his threads. It holds for very little time. Then drops pressure. In any case, I believe that your recommendation to switch to the yellow spring is probably a good idea.
