Build thread because why not
@wealthmanager - It was tuned it house. John Bray was in town, our in house tuner was home for the weekend, and we went out cruising, I turned the boost up 5psi but didnt pull any timing out, but who knows... Just speculating, the usb memory stick was in the laptop, not in the logger lol
Such a tiny hole, doesnt even misfire, drove it home after, just hear a very small hissing sound coming from oil tank side and see a little bit of gasket blown out.
Originally Posted by vcbgchgj
People don't often post this stuff so figured I would liven up the build related threads. Short block coming together. Ill keep adding as I go.
I'm all about sharing my pain and suffering in hopes that others can avoid it. Life is too short to keep rebuilding a motor over an avoidable problem.
Sean my .02 is the combination of the compression you went with on your piston, with Keeping the Stock Cams which Generate a lot of Cylinder pressure as you Know and not adjusting your Timing with Boost all these closed that Small Window to Begin with. At Least you got some fun out of it and I know you're gonna make it Bullet Proof now. I think you're gonna notice a huge change cleaning the Heads and the new Cams. Good luck and keep us Posted.
Sent from my iPad using 6SpeedOnline
What head studs you are using ?
EVOMS do not require a retorque procedure 12 or 10mm
You are not the first person with headgasket issues and using raceware headstuds.........
yes i have used them in my 996tt and they held up fine for a long time. when i turned it up i pushed the headgasket, that was before we O-ringed it. once it was properly O ringed the heads were on tight and car never showed signs of gasket failure event at very high boost and timing numbers. 155mph traps.
i purchased raceware again to use in my 997TT when time comes.
#TeamAIM
#TeamAIM
