Build thread because why not
Old Nov 28, 2014 | 11:53 AM
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
Copper doesn't require a receiver groove in the head as its softer, and I've always used copper on my builds without issue so until it lets me down, ill keep doing it
Old Nov 28, 2014 | 01:29 PM
Emmanuele Design's Avatar
Emmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond reputeEmmanuele Design has a reputation beyond repute
Following, looking forward to it!
Old Nov 28, 2014 | 02:48 PM
32krazy!'s Avatar
i thought there was a groove in the picture. so its laying on top? how do you ensure it doesn't move on install? wasn't questioning whether it is better or worse just wondering why you chose that material
Old Nov 28, 2014 | 03:16 PM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Serious build and thread straight to the point! This thread is going places.
Old Nov 28, 2014 | 04:36 PM
itguy's Avatar
Sorry didn't mean to come off as defensive
The groove was cut by LA Sleeve on request. Its a .02 deep groove and I used .03 wire. Its held in press-fit. I machined a aluminum hat to press it in evenly.
Old Nov 28, 2014 | 05:42 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Subscribed.......love me a good build thread.
Old Nov 28, 2014 | 06:40 PM
CBRacerX's Avatar
CBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to behold
Looks like fun!
Old Nov 28, 2014 | 08:58 PM
32krazy!'s Avatar
ok iwasnt thinking while i was looking. groove in the block but not in the head right?
Old Nov 28, 2014 | 09:01 PM
itguy's Avatar
Correct, sleeves grooved, not head.
Old Nov 28, 2014 | 09:06 PM
32krazy!'s Avatar
guessing your not in tn so i could watch this build come together!
Old Nov 28, 2014 | 09:10 PM
itguy's Avatar
Sorry, i'm, in Vegas
Old Nov 29, 2014 | 09:10 AM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
Not being critical just curious. From the pic it doesn't look like the cylinders have been honed, or at least there doesn't appear to be any crosshatching. Also I see what appears to look like a residual stain from the top ring near the upper part of the center cylinder.
My comment is based from working with non-plated iron liners. If these are plated, I understand the finish, still wondering the stain?
Looks like a fun project, keep the pics coming of the build.
Old Nov 29, 2014 | 09:18 AM
nick49's Avatar
Honestly not trying to be confrontational but was the wire malleable or did you flame anneal it? I take it you want it soft to seal and conform to any irregularities. Did you file to match butt the ends similar to what you might do on a piston ring? I do this type of stuff too and there is so little detailed tech discussion on these things I find it interesting.
I may have answered my own question, copper may come in contact with a soft fire ring on the head gasket not needing soft copper? Maybe I'm thinking too much, lol.
Another thing, what kind of top ring gap did you allow? Curious if you gave a bit more for a boosted motor and a built one at that. Thanks!
Old Nov 29, 2014 | 12:29 PM
itguy's Avatar
Never fear cross hatch is here The scar is wd40 that I didn't wipe away
And yes, you do try your best to butt the copper rings against each other, there is a technique used to install them where by they meet with a little pressure against the ends. I double o-ringed these so the butt joint is less crucial.
Top ring gap is 0.020, 2nd ring .026, piston to wall is around .00375 (and to anyone who has something negative to say about this, i'll happily blow my **** up and learn from it)
Old Nov 29, 2014 | 12:35 PM
32krazy!'s Avatar
since i haven't ever seen the rings outside the engine are these # custom by you or a normal spec gap for the engine? and don't blow it up! i want to see what you end up with power wise
since this isn't a diy for the novice are you a shop tech or just crazy about doing your own work and experienced with porsches?
