Where Can I Buy 315/30-18 Street Tires?
Old Mar 7, 2015 | 08:35 AM
  #91
rmc1148's Avatar
Yes mine is normal height as with the roads here I have found it hard on my lowered cars. The dealer said the alignment was out and the inside tread was the reason for replacement.
Old Mar 7, 2015 | 08:36 AM
  #92
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
Designed as a stock fitment, but appears to have plenty of clearance for the 380mm 997 brakes if I want to upgrade, stock twist's do not.
Won't have the rears for another couple weeks, weren't ready for pick-up last trip, tires in external warehouse.
Originally Posted by '02996ttx50
another good point, but theyre made with the 350's in mind no?
do you have rear shot pics yet? pls lets see them. thanks.
Old Mar 7, 2015 | 08:39 AM
  #93
993GT's Avatar
I'm locking down my front and rear suspension with solid caster pucks, LCA monoballs, toe-links...tire wear should be better, handling 'tweaking'/precision will be for sure
Old Mar 7, 2015 | 09:34 AM
  #94
'02996ttx50's Avatar
Yeah I finally went with the torque solutions t links and whether or not it IS the solution? Remains to be seen. but it just seemed foolish to continue with premature inner wear at 400/500 a pop.
Looking fwd to seeing the oz all setup when you get em !
Old Mar 7, 2015 | 11:14 AM
  #95
993GT's Avatar
Have Porsche Motorsports caster pucks, think of going with Rennline sealed monoballs for LCA inners and Champion toe-links...flex be gone! lol
Old Mar 7, 2015 | 11:20 AM
  #96
i'm trying to navigate that VERY thin line esp on parts that eliminate "rubber/poly" or anything that heretofore reduced nvh with the oem. but it's always a trade off. i'll never forget even my first trip around the block with semi solid mm's! dramatically tighter with minimal yet definitely noticeable added n/v.. if not H.
for that reason, and because my car IS technically a dual duty car, I've avoided mono ball anythings. though i did just give up on the tarett camber plates owing to install issues. but i know i'm not done with the lca's rear etc. i had found my oem links were pretty significantly BENT! and i managed to BREAK a gt3 sway! lol. gotta love hillclimbin
Old Mar 11, 2015 | 05:18 PM
  #97
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
Rival S on tirerack now, availability 3/30
http://www.tirerack.com/tires/tires....GFRS&tab=Sizes
Old Mar 18, 2015 | 08:05 AM
  #98
DaveSen's Avatar
DaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud of
3153018 PS2's available
If anyone is interested, I found a source for PS2 N4 rated. Simpletire.com
Pricing is comparable to tire rack, delivery was prompt. I was in a pinch with worn out rears and not wanting to change all 4 tires.
Not sure how many tires they have....
Old Mar 18, 2015 | 08:22 AM
  #99
pretty sure you can get em a lot of places for 544 a pop! me, i'll stick with the p zero n rated for 400. no way the ps2 is worth 140 more per copy. to me.
Old Mar 18, 2015 | 10:28 AM
  #100
DaveSen's Avatar
Tires
Just trying to be helpful guys....Tire Rack has been out for months, and Discount Tire will not even talk about them. I searched many places and finally found a source so I am sharing in case others are in the same situation.
I agree though for the street I will be going to something less $$ once the set wears out!
Old Mar 18, 2015 | 12:13 PM
  #101
didn't intend to criticize your effort! I just can find them anytime at 544. no harm, sorry.
Old Mar 22, 2015 | 12:21 PM
  #102
0396's Avatar
0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute
I just ordered a set of 4 from NewPort Porsche
Old Mar 27, 2015 | 02:41 PM
  #103
993GT's Avatar
got the rears today
and some LCA monoballs to match the metal caster bushings(will order the toe-links shortly) to better dial the suspension in and hopefully make this set of rear tires last long then the last set
Old Mar 27, 2015 | 04:53 PM
  #104
993GT's Avatar
now just need winter/salt to go away...
Old Mar 27, 2015 | 05:20 PM
  #105
got the rears today
what kind ya get? i recently put on the TS ones for more toe out in an effort to squeak oh i dunno, maybe 6k!? out of set of rears lol
finally too, ya got wheels! nice. I'm fence sitting while looking for used ha
