does cold weather promote over boosting?
I'd check your waste gates. My car boosts 1.3 bar no matter if its 90 or 30 degrees outside. I do seem to hit 1.3 bar a little lower in the rpm range with colder temps which makes sense due to the denser air.
.1 bar more... yes under colder conditions...
2001 996TT 3.6L and stock ECU
Normally yes you can make a couple of extra lbs of boost when its very cold but whats your reference, thats a hell of a spike if its stockish, becarefull.
^ my boost levels stay the same also ( 1.3 ) even in summer heat but cooler and most particularly fog (?!) the car just seems to "breathe" better and it sure feels a bit "quicker".
but definitely agree, waste gates improperly adjusted can/will cause "boost creep". i messed with mine for a cpl months until i got it sorted. i was getting 1.5 spikes and my car isn't set for that.
+1 on 993gt. feeling like more "power" but shouldn't boost higher. agree.
stop by I will find it... your N75 is probably leaking at the connections.. Wgs not opening up.... or even a tune etc...
I can't. I will come home with injectors and turbos.
I know i have a leak somewhere. Never really savvy with checking. Been wanting turbos from markski for a while and get it all sorted out. The budget always seems to go elsewhere.. :-/
