New B&M SSK
Old Nov 16, 2003 | 12:50 AM
20C4S's Avatar
any news on OEM kit?
Old Nov 16, 2003 | 12:59 AM
cjv's Avatar
cjv
Moderator
I used the EVOMS and the Ruf set at 50%.
Old Nov 16, 2003 | 11:00 AM
msindi's Avatar
Im in if there is a group buy tooo
Old Nov 16, 2003 | 11:09 AM
JM996's Avatar
JM996 is infamous around these parts
For those that have done the under car installation, how hard would it be to install without access to a lift? I only have a floor jack.
Old Nov 16, 2003 | 12:32 PM
MKW's Avatar
MKW
MKW is infamous around these parts
Easy. I did mine with a floor jack at the left rear , lifting car high enough to put a jack stand under the left rear cross member . Use wheel chocks in front of left front tire and behind right rear tire before crawling under car from the rear . DO NOT GO UNDER ANY CAR WITHOUT JACKSTAND AND CHOCKS !!!
Only " special " tools you need are T55 Torx bit, 4mm hex key or bit and everyday tools . The 2 cable end socket joints are easily popped off their ball joints by prying with either a big wide flatblade screwdriver or one of those angled /pronged screwdriver sized door panel pop-off tools, which I have. There are two cables back there. the upper one is the selector and is not changed in it's position. The bottom one is the shifter cable and the one whose pivot point is changed by this kit's aluminum block.
These kits are basically a 3"x2 " drilled piece of aluminum that clamps to the tranny shifter arm to change the cable pivot and a new bracket to move that shifter cable slightly outboard.
Probably $10 dollars worth of parts , asking $$$ by some vendors. Yeah , I know .... " R&D " costs...
Here's a pic of this kind of kit in this thread : Pic of B&M undercar SSK
Old Nov 16, 2003 | 12:53 PM
MTBR's Avatar
MTBR is infamous around these parts
Originally posted by KPV
Dan,
Chucky looks angry?
He's angry b/c I sold my Turbo and he's got no ride.
Fadi
Aug 17, 2018 05:16 PM
nick49
Jan 26, 2017 01:17 PM
Fadi
Oct 5, 2015 12:14 AM
steve harris
Sep 24, 2015 07:52 PM
orbelo
Aug 30, 2015 12:26 PM
