Coilover Upgrade - Supporting Parts for Street Car?
The solid thrust arm bushing in the rear are a huge improvement over stock with zero downside. One of the benefits is hugely improved rear tire wear due to the fact that you all but eliminate any change in toe under load. The stock rubber bushing allow a ton of movement especially as they age. You can't even compare the solid TA bushing to solid subframe bushings which will give you a negligible benefit on a street set up. Totally different animal with a similar sounding name...
as to the bent parts, given i have on many occasions snapped wheel lugs! it comes as no huge surprise my bashing up and down these mtn's has actually bent some of the oem parts in the rear
( sorry to the op..although this is now relevant to me in terms of parts though - the coils, but again.. sorry for interrupting your thread...)
Considering that aftermarket monoball upper mounts are ~500, isnt getting the GT2/GT3 DFV ohlins still a better deal? You also get camber adjustment/monoball mount instead of the stock turbo upper mounts.
For RWD I went through this process.. well to TBH Tim941NYC did it all.
I bought the GT2/GT3 DFV Ohlins for $2500 direct from Ohlins USA.
add
front wheel bearing $50
Perch and Top hats from a GT3 $500
GT2 uprights and PCCB hats for proper offset $1000
Stainless steel brake lines front and rear $125
ATE 4 brake fluid $20
Wheel alignment
Installed struts, flushed and bled the brake system
Total cost installed with labor $5500
add
Wheel alignment
add
Wheel alignment
add
Wheel alignment
I assume that you could get the ohlins kit for the GT2/GT3 and treat them like how you would install OEM GT2/GT3 coilovers on a 996tt by getting aftermarket monoball top mounts and putting a sleeve on the shock body.
The rear is plug and play.
add
Wheel alignment
Wheel alignment
Ok so now that i'm getting near the install phase of this in the next week does anyone have suggestions for what setting to put the Front and Rear Eibach settings on?
I'm not saying i'm an awesome driver so I don't want snap oversteer - just a nice neutral setup. Any thoughts or recommendations?
For the coilovers i'm putting them at the "10" setting which according to the instructions is the "winding road" setting. 1-9 is stiffer for the more track oriented setups.
I appreciate any feedback you guys have.
From the searching i've done for a street car it seems like going soft front / mid rear on the sways might be the best bet for a neutral setup and get rid of a bit of the understeer tendency.
TS ( for example ) toe links allow for a .027 toe/rear. which is just at the end of porsche spec, or possibly a smidgen outside. but best for even tread wear inside. so excessive "squat" under hard accel is compensated for.
I just got my car back today after having Ohlins R&T installed along with drop links, front monoballs, rear thrust arm bearings and adjustable rear sway bar. Can't wait to finish up the work day and start a weekend of driving!
