Coilover Upgrade - Supporting Parts for Street Car?
Old Jan 9, 2015 | 10:01 AM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
Tarett is an Ohlins dealer as well. Might as well just get everything from them (possibly).
I asked in another thread but didn't see an answer - why does the DFV model for 996 AWD cost almost $1k more than the DFV model for 996 RWD? Are both sets just 4 shocks and 4 springs, or does the AWD set come with something extra?
Other coilovers don't seem to do that (PSS10, KW, etc), in terms of a large pricing delta between RWD and AWD 996 configurations. So just curious.
Old Jan 9, 2015 | 10:36 AM
caraudio1's Avatar
caraudio1 is infamous around these parts
Turbo Kit
According to my rep the turbo kit comes with CNC'd drop links that affect the price.
Old Jan 9, 2015 | 01:15 PM
Scawt's Avatar
Scawt is just really niceScawt is just really niceScawt is just really niceScawt is just really nice
They come with brackets for the droplinks, not the actual links themselves.
Old Jan 9, 2015 | 07:03 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
A set of FVD re-valved PSS9's just came up for sale on RL. Only 6K miles on them.
Old Feb 14, 2015 | 12:25 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
Can I get the GT2 DFV kit if i've purchased new F&R Swaybars and the tarret droplinks anyway?
Just no reason to spend the extra 1k if i'm just buying the same parts twice.
Old Feb 14, 2015 | 05:24 PM
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
Great info in this thread! Subscibed!
Old Feb 16, 2015 | 04:08 PM
daedalus's Avatar
Been doing my research and spoke with Ohlins and Tarret and can report back with some information. Let me stress I still do not have parts in front of me to 100% confirm this so take it with a grain of salt.
The Ohlins GT2/GT3 kit re-uses the OEM F&R droplink brackets, and on the Turbo kit it includes new ones (as we do not have compatible droplink brackets on the 996TT). So you have two options:
GRAND TOTAL: 4735.00
GRAND TOTAL: 4175.00
So in theory you can get the GT3 kit, compliment it with missing equipment from Tarret for a savings of 560.00 and probably have better brackets and hardware that is all going to work together a bit nicer.
I'm all for saving 560.00 but a bit hesitant to be the guinea pig. What to do what to do....
Anyway - hope this helps future 6speeders.
Old Feb 16, 2015 | 04:28 PM
daedalus's Avatar
I should also mention both kits reuse the OEM top mounts. From what i've found the GT2 and Turbo top mounts should be cross compatible but I cannot confirm that. Anyone know? That would be the only other thing that I think would cause issues if they were not compatible?
Old Feb 16, 2015 | 04:39 PM
'02996ttx50's Avatar
i dunno about any of the above..? but i'll tell you right now..beware the tarret top mount/camber plates. cos something aint exactly right fitment wise, out of the box. i notice they are conspicuously absent from your parts list. i'd keep it that way. scratch this.... sorry. seems i need coil overs for the tarett plates to fit properly..which renders my complaint moot, since this is your coil over parts thread.
Old Feb 16, 2015 | 04:48 PM
Dr. Jekyll's Avatar
Dr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of light
How necessary do you think those solid thrust arm bushings are for a street car? I'll be picking up a set of adjustable toe links and locking plates and going with a GT2 alignment soon and am considering pwdrhound's suggestion about the thrust arm bushings. I'd like to do it right the first time and I know they are only $200, but I still don't want to throw money at suspension bits I'll never take advantage of.
Old Feb 16, 2015 | 05:22 PM
caraudio1's Avatar
Ohlins install manuals
Don't know if you guys have seen these, thought I'd post a link just in case.
http://www.roadandtrackbyohlins.com/...MI_POZMN02.pdf
http://www.roadandtrackbyohlins.com/...MI_POSMI10.pdf
Old Feb 16, 2015 | 05:38 PM
exactly. probably not necessary at all, solid thrust arm bushings aren't a "must do"? any more than solid rear sub frame's are on a street car. not worth the noise and resonance i would think, and handling just gonna get rougher and rougher for the street. etc. that's track stuff? yeah..? not "street".
but you'll be pleased with rss toe links or the TS ones. i have just put on my torque solution toe links and i'd say once i get them dialed in, they are a must have if you're "getting" serious. it will save me some of that toe issue on tread wear, as i'm already a bit lower than gt2 with roughly gt2 alignment specs. it's all about the toe ( i'm learning ) and the insane amount of squat i get when it's wot on twists.
Old Feb 16, 2015 | 11:08 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Im pretty sure you have to change the front top shock mount with using the GT3 shocks.
my buddy just went through this putting the GT3 DFV ohlins coilovers on his 996tt.
Old Feb 17, 2015 | 08:55 AM
daedalus's Avatar
^^ Thank you! That's what I was concerned with. I guess it's Turbo DFV's for me.
Old Feb 17, 2015 | 09:43 AM
pwdrhound's Avatar
The solid thrust arm bushing in the rear are a huge improvement over stock with zero downside. One of the benefits is hugely improved rear tire wear due to the fact that you all but eliminate any change in toe under load. The stock rubber bushing allow a ton of movement especially as they age. You can't even compare the solid TA bushing to solid subframe bushings which will give you a negligible benefit on a street set up. Totally different animal with a similar sounding name...
