When are injectors required over a 5bar FPR?
Old Feb 2, 2015 | 08:58 PM
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
Hi guys, I'm trying to figure out if there is any point in me going with 60lbs injectors over a 5bar FPR in a 996 Turbo with K16 Billets running anywhere between 1.2 to 1.4 bar of boost on 93octame pump (Haven't spoken to my tuner yet to decide on a boost level). Only other mod affecting this is an exhaust with 100cell cats. Would the tune with the 5bar be safe?
Thanks!
Old Feb 2, 2015 | 09:37 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
i think it depends on tuner.....more boost or more timing. either way, If you're out of fuel and start to run lean...it's time for injectors.
i've got k16 billets/5bar/IC/exhaust etc
I think i'm at 1.2bar but I can't go more. We've tired a little more boost and it started to run lean...that said I'm not sure if it's worth it for me to go injectors for the additional .1bar.
Old Feb 2, 2015 | 09:53 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
IMO, FPR is a 'Band-Aid', injectors is doing it right
Old Feb 2, 2015 | 10:53 PM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
IMO if ur doing billet 16's do the injectors as well as thats a guaranteed safe 550whp
Old Feb 3, 2015 | 03:40 AM
you cant go over 1.2 bar on Bk16 billets... injectors and oem FPR...
but thats all up to your tuner...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 3, 2015 | 04:58 AM
NTIMD8's Avatar
Thanks guys.
Old Feb 3, 2015 | 06:34 AM
NTIMD8's Avatar
Hi Markski, are you saying anyone with Billet K16 turbos should not run more than 1.2 bar? Doesn't AMS recommend running them at 1.4? Is 1.2 bar actually the top of their efficiency?
Thanks!
Old Feb 3, 2015 | 09:54 AM
NTIMD8's Avatar
2bar? Jeebus!!
Old Feb 3, 2015 | 12:20 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
Thanks!
I think he's saying on stock injectors AND FPR not to go over 1.2 on billet k16 upgrades.
Originally Posted by Tony@epl
The AMS turbo's work well right up to 2 bar. I had them on my last 996.
Wow really 2 bar on stock injectors and FPR????
Old Feb 3, 2015 | 12:31 PM
NTIMD8's Avatar
Ah ok that makes more sense.
I don't think Tony meant on stock injectors or FPR. He was referring to the limitations of L16billets in general.
Old Feb 3, 2015 | 04:40 PM
geetee's Avatar
83lb Bosch injectors and our intank pump set up. Sorry.. should have been more specific.
what kinda fuel were you on?
Old Feb 3, 2015 | 06:18 PM
Hi Markski, are you saying anyone with Billet K16 turbos should not run more than 1.2 bar? Doesn't AMS recommend running them at 1.4? Is 1.2 bar actually the top of their efficiency? Thanks!
Not on a 5 bar with stock injectors. With injectors and proper tune 1.4 is not a problem.
9.66
click to view
Old Feb 3, 2015 | 07:41 PM
NTIMD8's Avatar
Thanks Markski!
Old Feb 3, 2015 | 08:10 PM
geetee's Avatar
while we're on this topic
what difference are we talking about between 5 bar and injectors?
k16 billet/3.5 coolers/catless exhaust and 93 octane.
I know with the 5 bar....1.2bar is all
If i swap go back to 3.8 bar and add injectors...I can run up to 1.4 bar?
What is this 20-30whp difference?
Old Feb 3, 2015 | 08:36 PM
BLKMGK's Avatar
What size injectors? If fuel delivery is your limiter than upping the injector to the proper size will allow for more airflow until you hit an octane or strength limit..
