Wavetrac review
Old Feb 19, 2015 | 01:01 PM
mrmaass's Avatar
mrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond repute
Wavetrac review
I'm really glad I drove the car a while with no form of LSD after converting to RWD for a while before having a Wavetrac installed so I can truly appreciate what an improvement it makes! My car drives so much more predictably and smoothly now it is hard to describe but I will try. Of course straight line acceleration is better and on dry pavement there's no more wheelspin after 2nd gear and this is a huge improvement. In any turning situation under power is where it really shines. If I want to slide the back end it is very graceful now where one wheel drive it tended to be very difficult to slide smoothly. This is just a side benefit...I'm not into drifting but I really like being able to control my slides when I feel like it.
When I power out of a corner I can use a lot more throttle and it feels like both rear wheels are actually helping the car turn. The outside wheel feels like it is pushing harder and helping the car corner while the inside wheel contributes to forward momentum without going up in smoke! This is a dramatic difference compared to how it felt with the open diff. I can't wait for my first DE with RWD and the new differential. The price is too good to believe at ~$1200.
Installation was a pain for my shop because one of my carrier bearings was siezed and actually broke their puller! Still, if you're RWD this or a better Guard LSD is a fantastic upgrade and you will not regret it.
One issue is that PSM still gets in my way even when I shut it off. I plan on pulling the power to the pump before going to Thunderhill next month and leaving it deactivated permanently. Does anyone have an opinion for or against doing this?
Old Feb 19, 2015 | 01:04 PM
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
How many hours should have the install taken? Also, $1,200 for the LSD sounds like a bargain.
Old Feb 19, 2015 | 01:10 PM
pwdrhound's Avatar
Fully disabling PSM by disconnecting or removing the pump is the way to go. Treat the car with some respect until you get used to it since the nannies won't be there to help you out of a jam. I would tighten the front sway one notch from where you had it with the open diff to make the car a little more predictable at the limit.
mrmaass's Avatar
Original estimate was $1100 installed with all parts and new fluids and it ended up taking significantly more time. My shop is good but extremely expensive Thats why I do all my own work when I can but transmission mods are above my skill level.
Old Feb 19, 2015 | 01:16 PM
SamboTT@ByDesign's Avatar
Nice concise write up! I think it was $1295 now $1395. I have sold 5-6 now and everyone is happy!
Old Feb 19, 2015 | 01:29 PM
'02996ttx50's Avatar
yessssss....
i am always psm off ( see avatar lol ) unless a quick freeway jaunt, and i never have ANY issue with intrusion. that's weird.
congratulations. if more guys knew, more guys would do this. cheers and have FUN. whole different animal now.
Old Feb 19, 2015 | 01:50 PM
pwdrhound's Avatar
Originally Posted by '02996ttx50
yessssss....
Once you exceed a certain amount of slip angle, PSM will intervene even if you have it off with the button. The only way to fully turn it off is by disconnecting it.
Old Feb 19, 2015 | 02:49 PM
mrmaass's Avatar
Exactly...it's really annoying when I want to slide the car and PSM immediately kills the fun once I get started
Old Feb 19, 2015 | 02:55 PM
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
LSD on RWD cars makes a huge difference, I'm surprised there isn't more discussion about them considering how many people on here have converted.
Old Feb 19, 2015 | 03:03 PM
then i must be driving very safely, and conservatively john
seriously tho.. have had no intervention issues with dash button "off. just dont think for a moment i haven't made note of your pump disconnection your car is like my version of "no matter what i do, it'll never "catch up" lol
but see me on a hill? just kiddin
Old Feb 19, 2015 | 03:07 PM
agree, and flipside is worse. rwd on these cars withOUT some kind of an lsd whether its the looowwly and utterrrly useless wavetrac or a full blown guard, is nonsensical and even lame. bottom line is, open diff sucks.
Old Feb 19, 2015 | 03:35 PM
pwdrhound's Avatar
Mark,
You can install a simple on/off which in line with the PSM pump and have it mounted on the plastic shroud in the trunk as seen in the picture below. That way you can have PSM ON/OFF with the button, or a master PSM "totally" OFF with the switch in the trunk.
File Type: png
Old Feb 19, 2015 | 03:37 PM
rmc1148's Avatar
I like the switch install-clean!
Old Feb 19, 2015 | 03:40 PM
Mark,
john, you're the man. will have my buddy with the tool box check this out this weekend. you sir, are a font of valuable info, and i salute you. thx
add: stunned at the possibility of this... outstanding!
Old Feb 19, 2015 | 03:44 PM
Very nice John. All your stuff!
