Name that leak
Name that leak
Just noticed a little puddle of pink fluid in front of my left front tire, coolant level is OK so this must be minor for now.
I will put it on a lift and pull the wheel/fender liner for a look this weekend, any one had a radiator/fitting/hose leak there before?
Any ideas of parts I should have on hand?
Hoping that its just a loose hose but that's being optimistic
Definitely radiator in that position. Specifically, it's likely the seal on the endcaps of radiator weeping/leaking.
If one side is failing, the other side is not far behind and you might as well fix both.
Center radiator does not usually fail in unison.
Does it smell like coolant? I think there is a drain in the front for the evaporator - I've seen a nice clean puddle of water near there under my car as well. Check the smell/feel!
Well....tonight I removed the wheel and fender liner to inspect....no obvious leaks and held a 15 psi pressure test but corrosion was noted as well as dampness at the top seam where the aluminium meets the plastic part of the LF radiator, about 6" worth. Probably will be removing the bumper cover and replacing left side radiator before summer driving season. I guess its time to start researching options....replace culprit radiator....both sides.....all three hmm.
4 years ago
