Engine lid release button not working?
Old Mar 18, 2015 | 09:02 PM
Lucid Moment's Avatar
Lucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to all
Hey everyone, I have been working on my spoiler this week, and have had the engine compartment lid open several times. I have an 01 996tt.
Now I wanted to make some adjustments, and suddenly the button for the engine lid does not work any longer. The front trunk switch does work, so does the key fob remote for the front trunk.
Searched on the subject but didn't find much. The battery is new.
Can anyone point me in the right direction?
Thanks!
Old Mar 18, 2015 | 09:10 PM
I'll try and see if I can get the cable from the tail light. If anyone has other suggestions let me know.
Old Mar 18, 2015 | 10:06 PM
jayzbird's Avatar
jayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to behold
It can be tricky the first time. here is how I did it
Engine compartment Emergency Release
Located underneath L rear tail light. To access:
  1. Protect bumper with tape etc.
  2. Shine a flashlight in gap between taillight and bumper
  3. Use a hook to fish out the cable.
Here are a couple photos of the cable and the tools you'll need to fabricate
Old Mar 19, 2015 | 07:03 AM
Thanks, can anyone point me in the direction of why the switch stopt working? I know that may be a wild guess but I find it very odd that it just suddenly stopped working. Also forgot to mention, the switch makes no noise when engaged, as if it's not getting power. I know there are no fuses associated with the engine compartment lid. Anyone have an idea?
Old Mar 19, 2015 | 07:41 AM
rmc1148's Avatar
Check for power at switch and at latch, probably switch.
Old Mar 19, 2015 | 08:05 AM
jpflip's Avatar
The is always at least one fuse related to every electrical component on a car for overload protection. In the case of the engine lid the power comes from the alarm control unit. And the alarm control unit received power from fuse B8, E1 and C3. Take a look at these free fuses...
Old Mar 19, 2015 | 08:25 AM
rmc1148's Avatar
Good call Flip figured there was probably a fuse in there somewhere lol but personally have never looked= hopefully that will fix it.
Old Mar 19, 2015 | 08:41 AM
jpflip's Avatar
Thanks rmc1148, it is difficult to troubleshoot a fault when the signal goes into a control unit because we don't have access to the logic of the CU. But after a good fuse check it is good to check the switch, has you mention, and also to apply power directly to the motor or actuator to see if the unit is at fault….
Old Mar 19, 2015 | 08:43 AM
rmc1148's Avatar
All good points usually in that situation I have found something else amiss which leads me to the fuse.
Old Mar 19, 2015 | 09:05 AM
Thanks I had read to check C3, I'll check the others as well. I figured since I was messing with the electrical system for the spoiler that I somehow caused this.
Old Mar 19, 2015 | 09:06 AM
I'll update when I found out what's going on.
Old Mar 19, 2015 | 10:10 AM
'02996ttx50's Avatar
cant help with the engine lid, but anyone ever needs help with the frunk mechanism not working it's an air vacuum line that operates it and they heat up and go bad. also a 986 shared part. simple fix and same type of failsafe manual cable release. rear I would also guess a fuse as there isn't the same type of air pressured mechanism in the decklid
Old Mar 19, 2015 | 11:59 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
Thanks!
the rest of the car has power ?
Old Mar 19, 2015 | 12:51 PM
The rest of the car has power. Also checked the fuses and they are good. I'll try and get the cable today.
Old Mar 19, 2015 | 07:53 PM
Got the release switch to work. I checked the fuses, decided to to check other fuses as well, all of them just in case. All fuses were good. I then tried the switch again for hell of it. Sure enough it worked. At this point I am not sure why it didn't work, but I am happy it works again.
Thanks for all the suggestions and input!
