need help won't start
Old Mar 22, 2015 | 02:15 PM
rmc1148's Avatar
You could try a washer to make it more secure, nice to see you got it going.
Old Mar 22, 2015 | 03:07 PM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
Originally Posted by '02996ttx50
outstanding and well done. rep for sorting it out
Do I still get a rep even if I really don't know what thing I did fixed it
It just seemed like all the posts on the starter solenoid should be ridged. I just wish I knew exactly what happened.
Old Mar 22, 2015 | 03:37 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
Sometimes the starter solenoid internal contacts will arc and stick causing the starter motor to spin even though the pinion gear is not engaged to the flywheel ring gear. I have seen this many times. Disconnecting the battery or the starter is generally the only way to keep it from running. When power is reconnected and if you can get the engine started the increase in RPM of the flywheel will cause the pinion gear to over run and become disengaged. I have disassembled solenoids and filed the contacts and replaced the spring loaded contactor plate which sometimes is burnt. Not usually required, but can be done.
Old Mar 22, 2015 | 03:57 PM
z06801's Avatar
"Sometimes the starter solenoid internal contacts will arc and stick causing the starter motor to spin"
This sounds like what might have happened. starter rebuild?
Old Mar 22, 2015 | 05:05 PM
rmc1148's Avatar
I have seen that in older cars but I'm sure it can still happen. Have shop check out your starter new solenoid should be available separately .See ECS lists new bosch starter for 330
Old Mar 22, 2015 | 05:25 PM
z06801's Avatar
I just had a new built trans put in and now my clutch has a lot of chatter, its all brand new stuff that didn't chatter before the trans and motor were pulled so I have to take it out to see what going on. I'll address the starter then.
Old Mar 22, 2015 | 06:53 PM
'02996ttx50's Avatar
Originally Posted by z06801
Do I still get a rep even if I really don't know what thing I did fixed it .
of course, this sh*t is free lol
that said, it'd be great to actually know what it was that was loose, so next time it happens ?? some of us will know! lots of times the ground strap is loose for the _____ once the trans get pulled. who knows, could be,. either way. nice job lol
Old Mar 22, 2015 | 07:00 PM
rmc1148's Avatar
Sorry to hear about the trans issues=agree it makes sense to do it all at once.
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
ModBargains
Oct 13, 2015 03:52 PM
ModBargains
Panamera Vendor Classifieds
Oct 13, 2015 03:51 PM
