need help won't start
Old Mar 21, 2015 | 08:11 PM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
Went to start the car this morning, turned the key started to release the key but it hadn't fired up so I twisted back this all happened fast. it sounded like the starter was spinning and the airpump was on, but when I turned the key back to off they keep going had to disconect the battery to get them to stop even with the key out. Hook the battery back up and its still stuck on
Engine is not turning over.
Old Mar 21, 2015 | 08:12 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
Ignition switch?
Old Mar 21, 2015 | 08:22 PM
z06801's Avatar
That was my first thought,seems like crazy stuff happens when they go
Old Mar 21, 2015 | 08:26 PM
BLKMGK's Avatar
Replace it! Lots of crazy things happen when they go and while there's nothing in them they seem to go often.
Old Mar 21, 2015 | 08:27 PM
stilov's Avatar
Might as well try I think you can buy the Audi/vw part off amazon for like 10 bucks. I had to do mine. It was doing weird stuff.
Old Mar 21, 2015 | 08:31 PM
rmc1148's Avatar
Agree sounds like ignition but I have never seen those issues. Its odd you would hear starter but engine wasn't turning?
Old Mar 21, 2015 | 08:33 PM
z06801's Avatar
I'll try it, not the first time I've done it should be quick this time.
Old Mar 21, 2015 | 08:35 PM
z06801's Avatar
It might just be the air pump that stuck on.
Old Mar 21, 2015 | 09:09 PM
rmc1148's Avatar
Who knows lol hopefully that's it.
Old Mar 22, 2015 | 08:37 AM
'02996ttx50's Avatar
crazy electrical stuff happens. like phantom radio on/off, but usually the switch will still function? i also went with the 6 amazon 6$ vw/audi switch.
but this doesnt sound like a switch malfunction at all.
Old Mar 22, 2015 | 09:27 AM
z06801's Avatar
Originally Posted by '02996ttx50
crazy electrical stuff happens. like phantom radio on/off, but usually the switch will still function? i also went with the 6 amazon 6$ vw/audi switch. but this doesnt sound like a switch malfunction at all.
Where would you look next? Starter?
Old Mar 22, 2015 | 01:12 PM
z06801's Avatar
Wasn't the switch, found one at NAPA open on a sunday swapped it noise came back on and wouldn't start Need to determine what is actually stuck on, Is there a way to disable the air pump?
UPDATE: lifted car up to check the starter connections, the post on the small one on the bottom was kinda loose, tightened the nut up but it still wiggles a bit didn't seem right. connected the battery back up and things were normal. Nothing was running, car started and ran fine. Weird, still the new switch does seem to work better as the old one was showing signs of going out.
Old Mar 22, 2015 | 02:00 PM
racer959's Avatar
racer959 is infamous around these partsracer959 is infamous around these parts
When you tried to start it you said the starter was spinning. Is that right?
Old Mar 22, 2015 | 02:04 PM
z06801's Avatar
Not sure, the air pump was running even with the key off and out. updated above^
Old Mar 22, 2015 | 02:06 PM
outstanding and well done. rep for sorting it out
