Shifter knob, boot, and bezel
Old Mar 21, 2015 | 11:25 PM
carwash's Avatar
carwash is a jewel in the roughcarwash is a jewel in the roughcarwash is a jewel in the rough
Shifter ****, boot, and bezel
So I've gotten my numeric shifter and cup cables installed. At the point of getting the **** off my stock shifter, encountered it very hard to remove and it sustained some damage in the process. Bummer cuz it is the nicer 997 ****. But my boot and bezel aren't in the best shape either, and I guess from looking that they may only be available as one unit?
What's everyone's aftermarket **** of choice? Stock 996 eats *****. Stock 997 is decent. What's my plan of attack here?
Old Mar 22, 2015 | 07:03 AM
32krazy!'s Avatar
another 997 is the cheapest way. rennline makes a nice setup but all aluminum may get really hot in the summer
Old Mar 22, 2015 | 07:23 AM
carwash's Avatar
What holds the boot to the bottom of the ****? I think my 997 **** is missing something from the bottom of it.
If I did the rennline I would powder coat it gloss white. Same question tho, what holds the boot to the bottom of the rennline ****?
Also is there a company making aftermarket boots? Custom stitched like in white? My current boot has the plastic trim ring at the base.
Old Mar 22, 2015 | 08:31 AM
steve.rinaldi's Avatar
steve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to behold
I was debating on switching mine out as well just because it is wood grain. I ran across an illuminated one on Ebay from a German company. It is the entire shifter, boot and base for $150. Looks like a possible alternative. I have a Mac and cannot figure out how to cut and paste but search ICT Porsche 996 shifter. 2 different **** options and multiple different illuminated options.
Old Mar 22, 2015 | 08:51 AM
carwash's Avatar
illuminated seems gimmicky, and I can't imagine where you would pull the power from?
Old Mar 22, 2015 | 09:14 AM
32krazy!'s Avatar
Boot is sewn onto stock ****. Refitting the 997 needs tie wrap to secure boot to ****. Replacement boot on eBay in white stitch if you want. Reuse plastic bottom piece. **** simply pulls off with hurculean effort!
Old Mar 22, 2015 | 09:52 AM
carwash's Avatar
ah, gotcha on the zip tie... turn inside out, zip tie, then it folds over to make a smooth top I guess.
It doesn't look like the plastic piece will come off my boot. I have to look closer i guess.
Old Mar 22, 2015 | 11:12 AM
32krazy!'s Avatar
factory 996 shift boot has to be cut down off the ****. cut it as high as possible and then trim it down. if you want a boot with gold stitching i have one you can have. color didn't match for me. ebay special
Old Mar 22, 2015 | 11:40 AM
BLKMGK's Avatar
I had a custom alcantra boot made for my car and took pictures of the process for the vendor so that others could benefit. Contact http://z-interiors.com/shift-boots Zealous and ask them about it. Pictures of the process can be found here -> http://s272.photobucket.com/user/blk...?sort=3&page=1
Vendor price was VERY reasonable and he's been doing this for Subaru guys and others for awhile, his rep is excellent. You can choose material, stitching, and the result is awesome IMO. I kept the stock **** and didn't have to cut the boot to remove but a previous owner may have. I'd be interested in a better shift **** as mine seems awful light. Lemme know if you have questions and I'll try to answer them!
Old Mar 22, 2015 | 04:43 PM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
Here's the picture of the shifter
Old Mar 22, 2015 | 05:01 PM
32krazy!'s Avatar
thats a really nice looking shifter! think I'm going to order one. they do have an unilluminated version for 117$
Old Mar 22, 2015 | 08:58 PM
Slider's Avatar
I just bought some Alcantara-type material and made a pattern from the old boot. 20 minutes and it looks like stock (better). I re-used the stock plastic for the bottom.
Old Mar 22, 2015 | 10:59 PM
BLKMGK's Avatar
Pretty close to how mine was done although having a pro do the stitching was better than my attempts I'm sure! Folks can check out the pics I posted, I've also got steps written up that I helped Zealous create that are pretty clear. They provided some really nice glue though, not sure what it was but I'll be using it when I swap shift and e-brake boots on the RSTi soon. His parts really made it easy!
Old Mar 23, 2015 | 03:44 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
IIRC my Rennline **** came with a thick elastic band for the boot.
Old Mar 23, 2015 | 11:56 AM
Scawt's Avatar
Scawt is just really niceScawt is just really niceScawt is just really niceScawt is just really nice
Factory alcantara 996 GT3 RS shift **** is only $259 and takes 5 min to install.
