Moton clubsport questions
Old Mar 26, 2015 | 05:16 PM
pwdrhound's Avatar
Originally Posted by TighTT
Im curious to see the metal collars in place. Also routing (if possible) of canisters/hoses.
This is how you wanna route the lines and canisters... For the fronts you will need to drill a hole in the forward portion of the wheel well to run the lines to the trunk. Use a rubber grommet after drilling the hole.
FRONT:
[url=https://flic.kr/p/n5YYfX]
[url=https://flic.kr/p/n2CLuD]
[url=https://flic.kr/p/n2CNsM]
[url=https://flic.kr/p/n1NJiT]
REAR:
[url=https://flic.kr/p/n61Tu9]
[url=https://flic.kr/p/n1NPXX]
Old Mar 27, 2015 | 04:50 AM
TighTT's Avatar
TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !TighTT Is a GOD !
Thanks for the pics pwdrhound!
Does anyone know if the Motons I have (using Hyperco springs) require helper springs??
Old Mar 28, 2015 | 07:20 AM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
my Moton setup was rattling like crazy, never found the issue, i beleive it was spring size but still, i beleive the helper might have been my problem too. You can run them with or without helper, as you wish
Get a set of Tarrett top plate for the front also, make sure you mention you have Motons when ordering.
Old Mar 28, 2015 | 07:25 AM
pwdrhound's Avatar
With your spring rates, you will definitely want helpers to make sure your mains stay properly seated.
Old Mar 28, 2015 | 12:56 PM
TighTT's Avatar
Any thoughts on where to get them?? Also, recommendation on tender spring rates? Remember, Im a big wuss….looking for the best ride comfort possible. No track time.
Again, thanks for the help!
Old Mar 28, 2015 | 11:00 PM
pwdrhound's Avatar
You can get tenders from Eibach or H&R. Just google it. Eibach makes them in metric and standard sizing. Sizing is based on I.D. They also sell separator plates. Google "Eibach ERS springs". Go with 150# springs. They will be fully compressed at normal ride height and won't effect your ride at all. That is determined by your mains. I run 150 fronts and prefer 250 rears.
Old Mar 29, 2015 | 04:56 AM
TighTT's Avatar
Thanks for all the info...its greatly appreciated!!
Prepping the suspension:
Old Mar 29, 2015 | 05:14 AM
32krazy!'s Avatar
favor please. can you measure the overall length of the target drop links for the front and the bolt diameter of each end in mm? i need some new fronts and can't find any info relating to this. trying to see if they will fit my jrz fronts since the ones i have use different size threaded ends
and fwiw my coilovers are 600/800 with 225 lb tender springs. eibachs on jrz single rebound coilovers
PV=nRT.
Sep 9, 2022 06:06 PM
takenotes996tt
Jan 20, 2016 06:34 AM
nlakind
Nov 6, 2015 10:15 AM
pjb84
Sep 2, 2015 12:57 AM
