A comprehensive boost leak test Video- enjoy
Old Apr 6, 2015 | 01:29 PM
So a 6speed member came by and we did a quick boost leak test with my contraption. In this video I did it from the top of the Y pipe bypassing the ICs and hoses... but I strongly suggest you guys do it from the lower boost hoses...
He thought the car was running well as most do... get ready for this video sit back and enjoy...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 6, 2015 | 01:41 PM
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
Thank you marek for your video , the dealer will test it for no less than $800 here
Old Apr 6, 2015 | 01:56 PM
32krazy!'s Avatar
good video. spray bottle with soapy water will aid in finding this pesky leaks when your doing this as well
Old Apr 6, 2015 | 02:02 PM
Bader996's Avatar
Not all the time , but true some guys use it .
Old windex bottle with hand soap and water goes a long way. One thing didn't leak was the black check valve in back otherwise it would cover most issues.
Old Apr 6, 2015 | 02:24 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
good find, I bought Boost leak tester from markski few months back, its a good tool! saves you money and time, before tune !
Old Apr 6, 2015 | 02:30 PM
32krazy!'s Avatar
didn't mean it as a replacement but rather as an additional aid to your testing. I'm about half deaf and can't hear as good as seeing the bubbles to find the leaks
Old Apr 6, 2015 | 02:44 PM
jpflip's Avatar
Great! Thanks for sharing!
Old Apr 6, 2015 | 02:45 PM
I actually did it just not in the video, should have showed it.
Old Apr 6, 2015 | 02:55 PM
kylehohlier's Avatar
kylehohlier has a spectacular aura aboutkylehohlier has a spectacular aura aboutkylehohlier has a spectacular aura about
great video!
Page's Avatar
Page is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of light
I’m planning on dropping my engine sometime in the near future to do a clutch plus other things. Going to do a once over. I noticed that my Forge DV hose has crack marks on the bend that connects to the nipple. Seems like the + Batt terminal is not spaced high enough which caused some rubbing. (By who ever installed in previously.)
Before I move the engine, I’ll see if I can do a before and after test.
Markski - Thanks for the video and giving back to the community!
Old Apr 6, 2015 | 05:25 PM
Now u guys see what needs to be done and most shops don't even have boost leak tester. Smoke tests are usually low pressure and do not find all the drama.
Markski
Old Apr 6, 2015 | 05:36 PM
CTDan's Avatar
CTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond reputeCTDan has a reputation beyond repute
Rep points for you Marek... I sure appreciate the help you've been to myself and the site.
Old Apr 6, 2015 | 06:17 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Cool video. Shows the little spots that leak and have no idea wtf they are
Apex Chase
Mar 28, 2016 02:00 PM
AXARUNNER
Aug 28, 2015 11:33 AM
markski@markskituning
Aug 24, 2015 10:07 AM
Because_R4CEC4R
Aug 23, 2015 08:53 PM
magoochi
Aug 23, 2015 05:54 PM
