Efr7163 vs gt3586
Oh one more question when do you hit 20psi in say third gear?
this was before the efi turbos. i had a chance to watch my life pass before my eyes with sean driving this monster at a mere 900 hp! he can certainly build a motor!
https://www.6speedonline.com/forums/...e-why-not.html
Actually, I'm pretty sure Sean is 3.8, when you're swapping liners and rods might as well add pistons and go bigger! I don't think he's posted much in the way of graphs yet, he's still tweaking and developing
Edit: I'm wrong, 100mm pistons and not sure where that lands you with stock crank. Yup, looks like 100mm is stock! He did bump compression a bit.
9.4 996tt
9.0 997tt
I would run 10:1 only if E85 would be available in my area, I raised CR of my GTR from 9.0 to 9.5 and gained 30hp @stock boost (0.9bar), better spool etc...
I imagine that built engine with cams and valves that runs 10:1 CR is very powerful, I guess a similar setup on a stock engine with rods only would do 80-100whp less at the same boost
9.0 997tt
9.4 996tt
9.0 997tt
9.0 997tt
Hey guys
Iam installing turbos , the turbos are not even , one is sitting lower than the other , your kind support please . The right one looks higher, what do you think? Headers new . On my old headers and k24 , I had the same problem ( as I have been told when I installed my muffler ) is that normal ?
