Short shifter slack
Old Apr 9, 2015 | 11:13 AM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
As s65e90 mentioned
The white plastic had a dent, and i will try to repair it as he described.
Will update as soon as its done
Old Apr 9, 2015 | 11:37 AM
pwdrhound's Avatar
Originally Posted by Ronny-
Thanks guys, i understand that numaric is the way to go, but there are several things id like to upgrade before that.
From the looks of it the white plastic piece is not swappable?
Ill remove the quick shift tomorrow and have a new look and see if there is any way to fix this.
No, the plastic piece is not sold separately.
Do a search.... here is the latest issue and certainly not the first.. I agree with others, the B&M is not a very good choice. I had one on my car years ago and it was the worst of the lot. I've driven just about all of them and my order of shifter preference is PMNA Cup, 997.2GT3, 997.1GT3, 997SSK. Add Cup cables to it and you have shifter nirvana... Porsche engineers are not total idiots, they actually make pretty good stuff from time to time (coolant pipe glue notwithstanding....) There are many choices out there around the same $450-600 price point. Choose wisely....
http://rennlist.com/forums/997-gt2-g...ilure-fyi.html
Old Apr 9, 2015 | 11:58 AM
s65e90's Avatar
s65e90 is infamous around these parts
As s65e90 mentioned
Exaclty. Fill that recess to make it flush again and it will eliminate almost all of the side to side play.
Old Apr 9, 2015 | 12:13 PM
Ronny-'s Avatar
But all the Shifters you are mentioning have the same plasticpiece that wear out.
All the shifters including my b&w has a steel rod connected to the plastic piece in the picture in my picture above, so they will wear out.
997.2gt3 is the best imo as it has steel/nylon ends in the north/south part, but still when moving the stick right left you will eventually wear out the mentioned plastic piece on all those shifters right?
Old Apr 9, 2015 | 02:38 PM
pwdrhound's Avatar
I've never seen that plastic piece wear out on any of the GT3 or cup shifters. Maybe they are made of a harder material or the excess wear may be caused in your case by the metal aftermarket B&W parts. The 997SSK, 997.1GT3, 997.2GT3, and the 996Cup shifters have more metal parts in them in that order, 997SSK the least, 996Cup the most.
Old Apr 9, 2015 | 10:07 PM
BLKMGK's Avatar
Numeric is all metal, spherical bearings, a little brass.
I'd do the JBWeld, heat it to make it flow better with a hairdryer - that stuff flows like water if you warm it enough and should nearly self level!
Old Apr 10, 2015 | 11:43 AM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Any thoughts on the factory 996 SSK?
Old Apr 10, 2015 | 12:03 PM
pwdrhound's Avatar
The 997SSK is much better than the 996SSK which is more notchy in my opinion.
Old Apr 10, 2015 | 12:41 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
I now have a 997 shifter (not the metal bushed one) and a RUF short shift kit and its fantastic on 30% reduction
steve harris
Jun 10, 2017 12:17 AM
turb0terr0r
Sep 29, 2015 05:47 PM
bongnation
Sep 25, 2015 02:58 PM
997zen
Sep 7, 2015 07:13 AM
