Short shifter slack
Old Apr 8, 2015 | 01:22 PM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
Short shifter slack
Hi guys, im having a bit of trouble with my pretty sloppy gearstick.
After removing the centre console i see that the sideway slack is in the big white nylon/plastic piece.
Is there any remedy for this?
I filmed it and it can be seen at the very end here:
nevermind the front/back movement as this can easily be tightened from what ive just read.
Old Apr 8, 2015 | 02:25 PM
'02996ttx50's Avatar
is that b&m?? i'd get rid of it. 997ssk or better yet, numeric.
sorry cant help with more, but has to be just improperly adjusted? just like me lol. i would think.
Old Apr 8, 2015 | 03:40 PM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Originally Posted by Ronny-
Hi guys, im having a bit of trouble with my pretty sloppy gearstick. After removing the centre console i see that the sideway slack is in the big white nylon/plastic piece. Is there any remedy for this? I filmed it and it can be seen at the very end here: Video Link: https://www.youtube.com/watch?v=wpPEExWMYeY nevermind the front/back movement as this can easily be tightened from what ive just read.
Yes. The plastic bits wear out. Don't know the part number or if they are aftermarket bits but replacing them will resolve side play.
Old Apr 8, 2015 | 03:46 PM
32krazy!'s Avatar
numeric and done
Old Apr 8, 2015 | 04:20 PM
Ronny-'s Avatar
Thanks guys, i understand that numaric is the way to go, but there are several things id like to upgrade before that.
From the looks of it the white plastic piece is not swappable?
Ill remove the quick shift tomorrow and have a new look and see if there is any way to fix this.
Old Apr 8, 2015 | 05:01 PM
32krazy!'s Avatar
it looks like a b&m short shift and the best way to fix those os to toss them into the trash. just poor quality gear sorry
Old Apr 8, 2015 | 05:50 PM
steve.rinaldi's Avatar
steve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to beholdsteve.rinaldi is a splendid one to behold
I bought a cheapo off Ebay and there is the side play which is an OEM issue but the front to back there is zero slack. I would love to know more about a numeric shifter. I think I will search and see!
Old Apr 8, 2015 | 06:11 PM
s65e90's Avatar
s65e90 is infamous around these parts
The white plastic piece has developed a slight impression from being rubbed from the metal ball of the shifter. You can fix it and it will work pretty well. Do this:
Remove the shifter from the car and put on a bench. Turn it sideways and look near that white plastic pivot point and you'll see a pin that goes through the shifter cage. Knock this out and pivot the plastic up as high as you can and it will just clear the outer cage.
Next mix up some JB weld and have it flow very lightly and smooth into the little recess, as you can build it back up to be flush and this will fix 90% of the left to right slop you are experiencing. I have done this to that exact shifter and it worked well. (I did only use it for a few months though so I can't comment on longevity, but was amazed it worked as well as it did).
You can also use plastic weld as it may be more durable. Take it apart and look at it and you'll see the white plastic is indented where it has been rubbing the shifter arm.
Good Luck!
they run group buy pricing from time to time. should be about 650(?) =/-. grab one and as steve says, be done.
Old Apr 8, 2015 | 06:13 PM
s65e90's Avatar
Numeric still has a tad bit of side to side play as it is just the nature of the fitment Dan tells me. I'm actually waiting for him now for some closer machined tolerances on some parts to try and stiffen mine up.
But yes, the Numeric shifter is 1000000% better than OEM, or any other conventional SSK
Old Apr 8, 2015 | 06:22 PM
as i see it..if you're not a madly committed diy'r? there are really only two ways to go.
the 997ssk ( which i'll just keep, as i have no issues ). or the numeric. as it's the best aftermarket one for our cars.
or if you're SERIOUS then by all mean give some thought to an SQS sequential ( up/down/baddas*. ) but that a BIG deal plus $$$, not a twenty minute in/out lol
Old Apr 8, 2015 | 07:04 PM
32krazy!'s Avatar
as long as any shifter is in a plastic housing its going to be junk. remove the console have a buddy drive the car and watch this factory stuff flex as he bangs the gears. the billet housing of the numeric solves this issue. its not cheap but its the best shifter out there thats not in the 4 digit $ price range
Old Apr 9, 2015 | 03:30 AM
Ronny-'s Avatar
Good Luck!
Thanks, this was just what i was after.
But its strange that no one is producing this plasticpiece new
Old Apr 9, 2015 | 04:57 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Did you try contacting B&M?
Old Apr 9, 2015 | 05:04 AM
Ronny-'s Avatar
Its not the B&M piece itself that is broken, its the OEM plastic piece that is worn, so i dont think B&M can help?
