Should i stick to 0w40? or
5-40W here but I only use Liqui-Moly (That is my oil of choice for all my german cars of the past and present). I will not put mobil 1 my porsche and that was from experience with my Audi S4. Mobil 1 was always noisy on startup and about 1.5 qt of consumption every oil change , LiquiMoly zero issues on startup and consumption was less than a quart.
And that engine was damn hot all the time
I use it and love it. Not only does it have a decent zddp content (1000ppm) but I run it in my corvette track car. After 7 years I tore the engine down and the bearings looked great. This car saw 300° oil temps on track a few years ago before I had the cooling sorted out. After the rebuild I saw the cam was starting to eat itself which has nothing to do with oil, so I switched to 0-50 Mobil racing, which has a zddp of 1850 ppm, which is huge. I'm a Mobil fan.
So what weight do we think is good for a 70K miles and summer temps say in LA? Just curious as to what people think is best not trying to be funny.
Re the Slick 50 comment about does anyone use it? I believe there was a time that all US military vehicles used it! Also I remember a test where they drained the oil from 2 cars after one had been treated with Slick 50 and drove them around a test track, the one that hadnt been treated failed within a lap the other did many many laps.
Can't say the 4.2l V8 audi was crap since I never had any issues with it other than when I sold it at 145K it was due for timing chain guides were due at 100K
yeah, dry and getting dryer every day from what i hear. theres not even any undegound water left in kali. gonna get ugly here pretty soon.
Maybe anecdotal but since owning the car for over 120K miles and between uses of mobil 1 and liqui-moly, my oil consumption was lower with liqui moly than mobil 1. The startup noise with the oil was worth me stock up on the latter.
You can have some of ours. Rain rain and more rain.
From my reading the water problem in California and neighboring states is much worse then they would like the public to believe. Hopefully things will turn around. On the oil topic its nice to see we are revisiting the weight debate as I never get tired of the opinions lol.
If at 85F 0w-40 is not good enough, not "thick" enough, the engine has problems that a 5w-40 or even a 5w-50 oil is not going to solve.
That story about draining the oil and driving the vehicles around a test track is just so out there... come on. Do you really believe some oil additive in that small of a quantity could really take the place of oil? Heck even if all the "oil" consisted of just that Slick 50 additive and then to drain it out... Gimme a break.
0w-40 has good cold flow characteristics and yet has the "40" to offer protection in high temp/high pressure situations.
I would only add that if one lived in a very year round mild climate and wanted to run a "thicker" oil that 5w-50 (not a typo for 15w-50!) oil would be a good oil choice.
Up here in northern CA where winters are mild (seldom below freezing) and summers can be blazing hot (116F is the record high while 100F+ is quite common) I run both of my engines with this oil nowadays. But they both covered a lot of miles with 0w-40 with no issues. In fact the Turbo has 0w-40 oil in it right now -- courtesy of an oil/filter service I had done in Jan. this year at a mid-west dealer while I was back there on family business when it came time to oil/filter service the engine) and the engine is just fine. The engine has another 1000+ miles to go before it is due for its 5K mile oil/filter service and when the time comes I'll have 5w-50 used.
Not heard of anyone using a 10/60 hmm, my friends engine was built by one of the US's top tuners and it has 10/60 in it, the 2 top tuners I speak with in the UK use 10/60 in fact im pretty sure ive read on the US forums that Porsche OPC no longer use Mobil 1 0/40 but Mobil 5/50, anyway Ill stick with my 10/60 until the next ice age hits then ill move to a lower weight
Built engines can have quite different clearances/oil needs and what a built engine requires has no bearing on what a stock street engine requires.
While you are using a 10w/60 oil based on an engine builder's usage, I have come across engines built that require a 0w/00 oil. The engine is built with this oil in mind as this oil generates the least amount of hydraulic friction which is HP robbing.
The only real authority on what these engines require in the way of oil is Porsche. If one ventures off the reservation, so to speak, and choose to ignore Porsche, he can justify his oil selection by any means he wants. Doesn't mean selection has any real basis for being the right selection, though.
At that time, engine management systems were not chip-controlled and, after changing the oil and filter and introducing Slick 50, the treatment could be completed by idling the engine for 30 minutes. During that period users invariably found (I know I did!) that the idle setting had to be continually backed off as friction reduction caused the idle speed to increase.
As an empirical test, we also took three ordinary saloon cars to Mallory Park racing circuit. Two had been given the Slick 50 treatment. On arrival all three had the engine oil drained from the sump and were then driven around the circuit at a steady 50 mph. I recall that the untreated engine seized up within one mile, but the other two lapped continuously for 50 untroubled laps - one was being driven by rally champion Roger Clark.
