1000th Suspension Thread - Trying to condense info
Old May 14, 2015 | 02:34 PM
'02996ttx50's Avatar
Originally Posted by su_maverick
I think the main issue with the MO30's is actually finding them. Im somewhat tempted to give the BC's a try just for giggles to see what they can do. Especially since they can be revalved and use Swift Springs which I am a huge fan of.
But, if you decide to sell your MO30's I might change my mind
here ya go bro http://www.lufteknic.com
New genuine units are $450/ea for fronts, and $500/ea for rears. Heavy duty Bilstein (slightly stiffer than genuine) is $300/ea for fronts, and $400/ea for rears. This does not include strut bearings, bump stops, dust sleeves, etc.
Old May 14, 2015 | 05:21 PM
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
Regarding monoballs it really depends on what you tolerance for suspension compliance is and what other suspension parts you have going on. I have them on V3s and would not begin to describe the ride as 'harsh'.
Old May 15, 2015 | 11:43 AM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
There is a Bilstein option for sport shocks, that are basically the HDs but designed for lowered sport springs. Tire rack has em I believe.
Old May 15, 2015 | 01:11 PM
^ pretty sure those are the "b8"? but i am trying to ascertain the real world difference btw the bilstein b8's and the MO30's.
Old May 15, 2015 | 11:10 PM
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
I was speaking with someone tonight and he said that a company called Feal might be looking at making suspensions for the 996. They are single adjustable shocks but they work with you in regards to valving and spring rates when you place the order and they use Swift Springs from the start. Going to talk to them on Monday.
Old May 22, 2015 | 10:16 AM
CBRacerX's Avatar
CBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to behold
Thanks for putting this together.
Old May 22, 2015 | 08:25 PM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
I am running K-sport coilovers. Honestly, they are not bad and are 85% of the way to being great all around.
(+) Much better ride quality than stock (even though the car is much lower). Good overall handling and road feel.
(-/+) This one could go either way but I honestly think they have too much adjustability to get them dialed in properly.
(-) The 15% bad comes with driving the car hard through corners that have imperfect road conditions. If the suspension is under compression in the corner and you hit a bump or dip, it somewhat unsettles the car which is not confidence inspiring. I have since changed the preload and dampening some more but doubt it will eliminate this altogether. I need another spirited run to know for sure since you can't tell under normal driving conditions.
If it is still not to my liking, I'm giving KW V1 a try. Seems like the best option at the mid level price point.
Old May 23, 2015 | 07:56 AM
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
Here is IMHO the best option going for a 996, full Ohlins TTX kit.
Great suspension comes at a price though, you must combine that with some other part to get what you are paying for. People above say mono ***** and such are to harsh, they are wrong, cheap shocks are harsh. With good suspension components the only thing you get with solid parts like Rod ends and mono ***** is more noise, but why spend $$ on good boingers to leave mushy rubber components in there!!!!!!!!!!!!!!
Then you better get your ride heights right, then do a corner weight and good alignment to make it all work!
I have driven numerous cars, especially lowered ones, that handle and feel just gross!
http://performanceshock.com/index.ph...2c487cc76467c2
I'm also trying to find a thread I read recently where forum member Engine Guy was giving some great info on alignment specs for lowered cars.
Thanks!
That dude is totally sketchy.
https://www.6speedonline.com/forums/...ls-help-3.html
https://www.6speedonline.com/forums/...k-junkies.html
Old May 23, 2015 | 09:47 AM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
I bought a set of BCs used just as a stop gap for 650.00 they were only a couple months old off someone's car that went back to stock to sell. My intent was to just replace my worn out stock stuff till I could get some real stuff, but they have felt pretty good on the car no real complaints, so replacing them has become a not a priority.
Old May 24, 2015 | 11:53 AM
Thank you all for the responses! I will be updating the main post accordingly when I have some free time tomorrow (probably by the pool )
I think Im going to go ahead and try out these Feal coilovers. Im really excited about the custom valving from the get go and the Swift springs. I think they might be a good intermediate system for guys that only lightly track their cars but dont want to invest heavily in V3s or such. I havent gotten deep into any conversations with them yet but I will keep this updated.
Cheers!
Old May 26, 2015 | 12:00 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
i'm for sure going with coilvers and not springs, either i want h&rs or pss9s, and lower the car just about an inch.
Old May 26, 2015 | 03:06 PM
Engine Guy's Avatar
Gee should we get into the world of widening the front end, you use new control arms and adjustable dog bones and drive shaft spacers. That is a stellar mod for the handling of a 996.
Old May 26, 2015 | 08:31 PM
If you want to do the writeup for it then I will add it
Little too rich for me though
Old May 26, 2015 | 09:15 PM
I have updated the main post with new info.
Someone PM'd me saying that Koni does actually make a set of shocks for the 996 Turbo. I have asked for some clarification on this and will update accordingly if true.
Old May 27, 2015 | 09:33 AM
AZ996TT's Avatar
AZ996TT is just really niceAZ996TT is just really niceAZ996TT is just really niceAZ996TT is just really niceAZ996TT is just really nice
Koni
after working with Koni, they do not in fact make a set of shocks for the C4/Turbo/GT2/GT3. They do make the C2 version.
