Question: How much oil do you burn?
Old May 31, 2015 | 08:32 PM
  #61
rmc1148's Avatar
The stuck plug was on one my Audi differential and was surprised as its been out before= bought new plug and used anti=seize. Luckily with my 996t everything comes loose easily.
Old Jun 1, 2015 | 03:00 PM
  #62
khiroshima's Avatar
khiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond repute
Originally Posted by dlmack111
Zero!.......123k, 5/40 & 5/50 (rotella T6 & castrol-didn't care for the castrol, t-6 proves to quiet the ims gears a bit)....even after 2 hard track days, the bars did not move.....I have put about 5k since ownership, changed the oil twice.
Glad to see this, I can report zero as well, 5k under my watch . . . KH
Old Jun 2, 2015 | 07:26 AM
  #63
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
for the next oil drain, ill try to drain the tanks again, btw, do you think if its ok to use PB Blaster and spray directly on screws. leave it, soaking overnight.?
Old Jun 2, 2015 | 07:36 AM
  #64
rmc1148's Avatar
The spray will usually help and letting it soak in for a couple days doesn't hurt. Now we will have the spray lube debate lol.
Old Jun 2, 2015 | 09:12 AM
  #65
Shadetree996's Avatar
Shadetree996 is infamous around these parts
Its not simply a matter of spraying the lube! Careful consideration needs to be given with respect to the precise delivery methodology used to apply said lube.
With or without the red tube?
Old Jun 2, 2015 | 10:25 AM
  #66
MadWhip's Avatar
yes, yes. which spray should we use....wd40 or pbblaster
Old Jun 2, 2015 | 10:34 AM
  #67
rmc1148's Avatar
I like Pb but just bought some crc freeze off to give it a try, kroil (spelling?)is top notch also.
Old Jan 29, 2023 | 02:59 PM
  #68
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Freshly rebuilt X50 from Porsche with 1200 break-in miles.
At 1200 it's within a 100 or two of needing it's 3rd qt since new motor fire-up.
Yep, we have issues and are in the process of figuring it out.
Old Jan 29, 2023 | 05:02 PM
  #69
pwdrhound's Avatar
What type of break in did you do? Gently break ins often do more harm than good because the piston rings may not get properly seated resulting in high oil consumption. Every engine I've had built has gone straight to the dyno run at max boost to redline and then straight to the track. They hardly ever burn oil.
Old Jan 30, 2023 | 02:03 PM
  #70
GreggT's Avatar
Thanks.....however, too late for me now.
I kept it under 4500 for the 1200......unfortunately that was the way I was brought up .
Old Feb 4, 2023 | 10:20 AM
  #71
'02996ttx50's Avatar
7 years since my previous post in this thread the good news: same oil consumption of M1 5/50.
1 qt per 1k miles.
Old Feb 6, 2023 | 04:30 PM
  #72
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
1 qt per 1k miles.
Sounds acceptable. I'm convinced those that claim extremely little to none, never check their oil. Hell, my old ladies Boxster and the Subaru I bought new use oil too. I think it's a Boxer thing. All my P cars consumed, TT or NA.
Old Feb 7, 2023 | 01:44 PM
  #73
funny you should mention that. I once would check the oil randomly but frequently using the stalk at red stoplights and would race against the measurement or the stoplight going green.
more "wins" when it takes "5" seconds than when it said measurement in 10 seconds+ or car must be "stationary and level".
I'm glad I've outgrown that. was s stupid game ha
still don't drain the turbos however
E55AMG
Jan 26, 2013 07:03 AM
glpdx
Apr 8, 2006 08:16 PM
TheJudge
Nov 12, 2005 07:28 PM
Hungry4$$$
Sep 27, 2005 07:27 AM
ben, lj
Cayenne 955/957
May 31, 2005 09:10 PM
